Old 02-13-2015, 02:25 PM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: 75 Nova U/SA
Mike, Hedman makes the #68310 (1.5" tube convention style header) for the G bodies. Just looking at them, I don't think there would be too much involved in getting them in a Nova subframe. Hedman's #68311 is the same header with a ball flange at the rear rather than a flat collector flange. A set of these and those inexpensive OBX collectors could be a nice cost effective setup.
I've got experience with Schoenfeld headers and ran a set of their 1 5/8-1 3/4 steps with Performance Welding merge collectors last season on my stocker. Schoenfeld seemed good to work with as I ordered my headers with the collectors loose in the box, Maybe they could do a set of 1 1/2" for 'ya. -Al
"That'll never work....."
Old 03-11-2015, 09:05 PM   #2
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
After looking at videos of some test runs, gonna go for more rear gear. Found a brand new Richmond 5.57 for a super price, will be in before the weekend(thanks Doug Smith), plan to test this SundayMight be a bit much for 1/4 mile, but will surely be fine for 1/8. We shall see! Also got some OBX merge collectors, they are stainless so took them to a welding shop to get some tabs welded on.
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-12-2015, 07:03 PM   #3
danny waters sr
danny waters sr's Avatar
Nice Mike
Old 03-16-2015, 07:07 PM   #4
MikeMoller
MikeMoller's Avatar
5.57 gear helped, about .2. Only made 4 runs, still need more work.
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-31-2015, 05:39 PM   #5
MikeMoller
MikeMoller's Avatar
Updates
So took the car to a lumberyard and got it weighed, had to add 150 lbs. Disappointing that it was that light. Also occurred to me that the drive shaft did not have much play, just barely could get it in, the ujoint had to be turned to get it in. Fortunately, it had the bigger trans yoke, so swapped that out with the smaller one just to make there is no bind going down track. Cut 6 inches off the collector to get total of 19. Thinking the 25 inches was to much and hurting mph. MPH is 70 at the 1/8, and 86 in the 1/4, seems like it should be higher than that in the 1/4.
Went to Dinwiddie/Richmond for a CCRA race, and only got to run 1/8. Run one was 9.39 @ 70.13mph. Went from 69 jet to 66 jet, changed timing from 42 to 40. Went 9.40 at 70.02. Had to leave it alone for racing at this point, won first round 9.40 @ 70.01. Lost next round 9.359 @ 70.25 (broke out-9.38 dial).
For the last run, left at 3300 instead of 3000 - it was close to overcoming the brakes - and up 100 rpm on both shift points -5300 and 5800.
60 fts ranged from 1.94-1.91, 330's 5.91 - 5.89.
Mike Moller
NHRA 203 Q-R-T/SA
