Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 04-17-2008, 02:19 PM   #1
Tilley2007
Guest
Posts: n/a
Default Re: Rod length? Piston speed?
The longer the rod, doesn't the piston stay at TDC longer, therefore slowing piston speed down? Why do a lot engine builders say that long rods won't work for a short stroke engine? I've been curious about this for awhile. Thanks
Scott Tilley
IHRA
SS/PDA2
Old 04-17-2008, 04:21 PM   #2
crazyponcho
I think that a lot of the short stroke engines run a low deck block thus negating some some of the benefits of a long rod since you can only run so short of a compression height. But I did freshen an engine not to long ago that had a three inch stroke and 6.2 in rods in a standard block that was at the top of its class, made for some real light pistons.But there is just as many opinions as there are engine builders.
crazyponcho is offline   Reply With Quote
Old 04-27-2008, 02:04 AM   #3
NovaMan
NovaMan's Avatar
You are both correct: a longer rod makes for a slightly lower piston speed.
Let's look at a 454BBC at 6500rpm. With the stock 6.135" rod, the peak piston speed is 7162.2 ft/min. If you go to a 6.385" rod, the piston slows slightly to 7135.4 ft/min. If you cram a 6.535" rod in there, you'll get the peak piston speed down to 7140.5 ft/min. That's less than a 1% difference.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
