Old 05-14-2021, 12:58 PM   #26
Marty Knox
Liked 44 Times in 19 Posts
Default Re: Not for Nuthin' But Close!
I started dis-assembling the car to install the cams and, as I tend to do, went about checking timing marks and lining things up and came to find out that the exhaust cam was retarded one tooth on the gear! The intake cam is where it should be.
Could this be why the car didn't respond to the header? What should I expect from this thing now? I'm not going to put the exhaust cam back where it should be and take it to the track which is what I should do. Any comments, suggestions, phone # of a good therapist?
So, if you're not going to do what you should do, what ARE you going to do? Put it back together with the new cam?
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
