Liked 747 Times in 362 Posts
Since it was running C/S, I have to assume it was running the top option Tri-Power 389, which was 360hp, according to Class Racer Info. The next lower hp looks to be 335hp, with 1 AFB 4-barrel. That engine would run a lower class.
http://www.classracerinfo.com/Engine...3&MAKE=Pontiac The Royal '66 also ran C/S. I assume that was the highest class a '66 could run, in '66. Not sure tho. Just looked back a few posts & realized that you were asking about the '69 D/SA Judge. From everything I can find out, D was the highest class a '69 could run, that year. That would mean that the D/SA '69 Judge was running the 370hp RA4 engine. As far as I know, the NHRA min weight for a '69 has always been 3500lbs. But I have no idea what the NHRA hp factor was at any given time, back in the old days. Last edited by oldskool; 10-23-2021 at 02:42 PM. |
Liked 48 Times in 44 Posts
(From PG12)
I have Bunkers car as a 69 GTO, RA4 factored to 380hp, same factoring as 1970-71. 3500/380=9.21 NOTE this has some implications for Ben Wolf's car from Spring 69. Unless NHRA de-factored the RA4 from eg 415hp to 380hp DURING the 1969 race year (highly unlikely), this means there's no way a 69 GTO factored at 380hp could run B/SA=8.00 class. Also, a 69 Firebird RA4 factored at 380hp does not fit B/SA=8.00. And, a 68 Firebird RA2 only fits if factored to 395hp or higher. Would a RA2 be factored HIGHER than a RA4? Seems unlikely. I'm wondering if the Ben Wolf B/SA=8.00 car was a Pontiac at all! Last edited by DeuceCoupe; 10-30-2021 at 12:02 PM. |
