#111 |
Liked 12 Times in 12 Posts
Just a few more shots of the '69 SC/Rambler...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() http://www.streetlegaltv.com/feature...rst-scrambler/ |
#112 |
Liked 44 Times in 27 Posts
"The Persuader" in the pits at the 1968 AHRA Nationals held at New York National Speedway.
![]() M68
"The more corrupt the state, the more numerous the laws." - Tacitus |
#113 |
Liked 10 Times in 10 Posts
I remember that car.
Ronnie Holland out of Hyannis, Mass. from Cape Motors. The sedan was equipped with a 343. If I recall correctly, that car was briefly an AHRA National Record Holder in Formula 4 Stock D/S AHRA Record 12.83 @ 109.46 MPH That car flew back in 1968. Last edited by Paul Ceasrine; 09-01-2012 at 05:35 PM. |
#114 |
Liked 18 Times in 12 Posts
Ya just got to love the Red-White & Blue paint themes, these cars rule!
"Real Race Cars Have Tailgates" |
#115 |
You gotta love those lightweight,,,,, 343 cubed cars.
#116 | |
were built by the factory as a 'regular stocking order' Do you have any info on these 2 americans ? Which dealers , VINs ,etc ? |
#117 |
Liked 56 Times in 29 Posts
The local dealer in Huntington, WV had a couple new 1967 Americans with 343 and 4 speed. I test drove one. . .
#118 |
#119 |
Liked 3 Times in 1 Post
Jeff i purchased a new "B" scheme SC/Rambler in 1969. Its weak points were the axles ,clutch, small carb. I put henry's axles in rear leaving stock 3.54 gear and added a heavier pressure plate. With a set of slapper bars and stock torgue links the car would hardly spin when launched at 5,000 with street tires. Other mods an offenhauser manifold, 750 holley, advance kit in distrib. I used stock cam but shimmed valve springs and installed antipumpup lifters. with combination I could leave at 5,000 shift at same and it would run 6,000 in highgear. It was a killer on the street as most cars I ran against couldn't hook or run as fast on top end.
As you know I have been racing these AMC cars ever since.
Mike Withers 1195 SS |
#120 |
Rambler Typhoon was actually the name of the 232 6cylinder engine introduction .AMC made 2520 Rambler 770 classics Badged Typhoon.All cars are solar yellow with painted black roofs. All had Ambassador dashes,all had black interiors. All were 2 door hardtops,1 year only.When Amc introduced their new V8 design ,,they took the typhoon name from the 6.I believe the typhoon. Name was only used for the 290 and 343 V8 engines.
