Old 04-14-2024, 11:54 AM   #11
rboyle
rboyle's Avatar
Liked 554 Times in 156 Posts
Default Re: XS Lithium batteries
I ran Anti Gravity lithium battery sometimes and never had an issue. Had to use a lithium smart charger with it and mine was a 12v.
Had enough juice to adjust the valves and spin it until oil pressure builds then start it. Cool down too. Weighed 4 lbs versus 42 lbs red top Optima
Old 04-14-2024, 03:26 PM   #12
jaspdot
Liked 3 Times in 2 Posts
Originally Posted by Fred Elsass View Post
Want to take 30 pounds off the front of my Maverick. Has anyone out there had any problems with a XS brand lithium battery????
The part number I am looking at is XS PWR-S5-1200.
Thanks
Sarge
Fred, give me call about batteries. Jim 618 920-6269
jaspdot is offline   Reply With Quote
Old 04-14-2024, 09:38 PM   #13
1320racer
1320racer's Avatar
Liked 401 Times in 192 Posts
Originally Posted by fred elsass View Post
thanks for all the input. How do i contact heather christian??
Sarge
941-539-4553
Old 04-18-2024, 02:13 PM   #14
2Ton71
2Ton71's Avatar
Liked 13 Times in 5 Posts
I ran (2) XS S1600 Lithium batteries last year with great results. No issues at all, doesn't require a special charger.
Andy Warren, FSS/E 3464, A/NMC 1
10 Time NMCA Nostalgia Muscle Car Champion
2020 NMCA Stock/Super Stock Combo Champion
2Ton71 is offline   Reply With Quote
Old 04-29-2024, 01:53 PM   #15
Altronics
Sponsor
Altronics's Avatar
Liked 58 Times in 9 Posts
All lithium batteries including Lithium Iron Phosphate "LiFe" can go into Thermal Runaway!!!
These are the same type of LiFE batteries that are in every brand mentioned in this post.
The only way to prevent Thermal Runaway is if Battery has a Proper BMS (Battery Managment System) designed in.
If you are looking at using a battery that does not, you are literally playing with fire.
Does a battery with a BMS cost more? YES
Is the Battery design more complicated? YES
Are there more things that could be wrong with a BMS controlled battery vs. one with a bunch of cells wires together? YES, but the safety far out weights the alternative. Would you rather have a battery quit working or start your car on fire?
Our Powerlite batteries have a Full 4 Year Warranty. We have had Zero failures in the BMS/Battery in the last 3 years and 0.01% since release.
If you would like more info on one of the only SAFE batteries in motorsports please contact us.
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
