11-18-2014, 01:52 PM | #1 |
Liked 12 Times in 6 Posts
LT-1 freshen-up
Planning on a ring freshen up on my LT-1 shortblock this winter. I do not intend to replace pistons, so I am looking for advice on rings/honing process. The motor has Lunati L350 pistons with 1/16, 1/16, 3/16 ring grooves.
I would like to consider a range of options and pros/cons for each. I reviewed a lot of the old threads on here, just looking for latest thinking. Total Seal recommended AP gapless top, Napier second, low tension oil. Saw good/bad input on gapless. Interested to hear input. This is not a high dollar deal. I am willing to spend a few bucks, but I don't want to break the bank. I also realize you get what you pay for. Thanks for advise/input. I have access to a couple great shops to perform the honing properly. Thanks, John |
11-18-2014, 03:19 PM | #2 |
Liked 1,650 Times in 504 Posts
Re: LT-1 freshen-up
Stay away from the gapless rings. They caused me to freshen my engine after one run. Total Seal could not tell me why the rings failed after just one pass. Other than that Total Seal should be able to steer you in the right direction. I have had good luck with their more standard ring packages. Make sure that you have a good machine shop that is experienced with racing engines hone the block and has a honing plate for your block
Mike Pearson 2485 SS |
11-18-2014, 03:24 PM | #3 |
Liked 9,499 Times in 1,967 Posts
Re: LT-1 freshen-up
I don't think you can go wrong with Greg Luneack at Tri City Competition.
11-18-2014, 03:33 PM | #4 |
Liked 2,713 Times in 854 Posts
Re: LT-1 freshen-up
If you're at location shown on your profile I'd just jump on I-75 South to Dayton and give Bruce Parsons your stuff....A1 job. Agree with Mike on the Gapless but each engine builder has their own unique take on a ring package and it could very well be influenced by your current pistons if you're intent on using them.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock |
11-18-2014, 06:25 PM | #5 |
Liked 18 Times in 4 Posts
Re: LT-1 freshen-up
Like Larry said, I don't think you can go wrong with Greg Luneack.
11-20-2014, 06:21 AM | #6 | |
Liked 136 Times in 43 Posts
Re: LT-1 freshen-up
Call Bruce, you won't be disappointed. He did my LT1. He know his stuff! |
11-18-2014, 06:36 PM | #7 |
Liked 158 Times in 73 Posts
Re: LT-1 freshen-up
a wet mag test on the crank and rods...hundred dollar investment to be assured of crack free, highly stressed components.
11-19-2014, 10:01 AM | #8 |
Liked 422 Times in 29 Posts
Re: LT-1 freshen-up
X3 on Gregg Luneack's rings as I machined a LT1 for a friend and used Gregg's rings and they work awesome. I am currently machining another one for my Daughter and I am using the same ring package. Give Gregg a call you'll be happy with the price and service.
Darcy Clarke 6254 A/SA SS/JA |
11-19-2014, 10:23 AM | #9 |
Liked 234 Times in 63 Posts
Re: LT-1 freshen-up
Greg is good
John Dinkel 3295 STK |
11-19-2014, 12:17 PM | #10 |
Re: LT-1 freshen-up
Thanks everyone. Looks like a call to Greg is on the agenda.
John |
