Old 03-04-2015, 08:27 PM   #11
Lou Jeffery
Default Re: GM 8.5 ten bolt crush sleeve
The easiest way to understand the function of a crush sleeve or solid spacer is to compare it to front wheel bearings on a spindle.
Ever notice how little amount of torque it takes on the spindle nut to cause drag? Then we back it off slightly to give running clearance. That said our pinion bearings require NO running clearance they actually require preload that we measure in a torque to turn sequence. So we know that when we torque a nut pushing two tapered bearings together we cannot have much torque or the bearings go metal to metal and will not rotate.
Now we either install a collapsible steel sleeve called a crush sleeve or we install a solid shim spacer between the pinion bearings so we can achieve our torque to turn measurement and be able to have adequate pinion nut torque.
The crush sleeve although commonly misunderstood as being somehow inferior has one limit and that is the amount of torque it takes to yield and collapse. If it yields at 250 ft.lbs. that is the maximum torque able to be applied.
The solid spacer commonly used in Dana axles and now aftermarket applications has no limit because it is not compressible.
Either is suitable with the crush sleeve being Much less time consuming.
No matter what application, amount of load, RPM, pinion angle, brand etc. etc. The crush sleeve or solid spacer cannot be affected in any way until bearing failure.
One last thought " Inadequate preload causing gear deflection consumes more energy than proper preload drag"
Lou Jeffery is offline   Reply With Quote
Old 03-05-2015, 10:29 PM   #12
DIV3CR
Liked 3 Times in 1 Post
Is the 12 bolt solid spacer the same for the 10 bolt-8.5
DIV3CR is offline   Reply With Quote
Old 03-05-2015, 11:03 PM   #13
Liked 4,447 Times in 1,693 Posts
No.
The 12 bolt goes from inner to outer inside bearing races.
The 8.5 (and the 7.5) seats against a shoulder on the pinion ,and loads the outer race only. The 8.8 Ford has a similar setup.
We are lucky we don't get as much Government as we pay for..... Will Rogers
Old 03-12-2015, 08:13 PM   #14
MikeMoller
MikeMoller's Avatar
Liked 242 Times in 72 Posts
Thanks for all the input guys.
The rear gears got installed today(thanks Doug Smith), elected to use the Ratech crush sleeve and it worked really well. Minimal effort to get the preload, if anything you need to be carful not to over tighten.
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-17-2015, 08:10 AM   #15
henrys57wagon
henrys57wagon's Avatar
No.
Years ago I made solid spacers for 12 bolt's and when I was going to put an 8.5 in my HenryJ I looked at making a solid spacer but have it go from bearing to bearing. Went to a 12 bolt instead.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
