Old 06-02-2015, 09:12 AM   #1
buzzinhalfdozen
Liked 12 Times in 9 Posts
Default Onan 7500 diesel
Gen. set runs OK, produces good power but has always since I've owned it had a "hunting" rpm. Most times it just runs at a constant rpm, but with almost any added load it seems to ramp up the engine speed, at times it will go up and down slowly. Serviced it last fall new filters oil ect. Thought I recall reading somewhere that these basically run at a constant rpm, is this a sign of an issue? Thanks Joe
Joe Buchanan SS/BX 3117
Old 06-02-2015, 12:28 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 510 Times in 200 Posts
Default Re: Onan 7500 diesel
If it is an Inverter type it is normal. They don't run at a fixed speed and engine speed changes with load demand.
Onan 7500 diesels are inverters usually..
Model Letter code ?
Rich Biebel
S/C 1479
Old 07-02-2015, 12:53 PM   #3
racer3694
Model Letter code ?
I had to replace the brain to my 5500 quit diesel. You want the old box to play with?FREE
racer3694 is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
