03-27-2017, 05:57 PM | #1 |
Liked 288 Times in 78 Posts
69 camaro rag joint
03-27-2017, 07:48 PM | #2 |
Liked 228 Times in 78 Posts
Re: 69 camaro rag joint
You should be able to gently tap the column flange into place. It slides out, and fasten with the 5/16NF & 3/8NF hex nuts and bolts along with the reinforcement washers supplied with the rag joint when purchased. MB
03-28-2017, 05:37 AM | #3 |
Tried that with no luck. Is it possible to slide the whole column down?
I have another column floating around. I'll check if that flange will slide out. I will post everything in my build thread but it's been a challenge to get the steering situated |
03-28-2017, 10:44 AM | #4 |
Liked 280 Times in 150 Posts
Rag joint(steering coupler)-- for 67-69 manual steering is GM # 7806391 pinch bolt is 7807271---Fed 387
03-28-2017, 10:50 AM | #5 |
67-69 Camaro PS rag joint is 7806390--Fed 387
03-30-2017, 10:11 AM | #6 |
Liked 7 Times in 6 Posts
ps boxes have different size splines/shafts that manual boxes.
is that a manual Camaro box or a vega?
without losers,winning means nothing. |
03-30-2017, 11:44 AM | #7 |
It is a camaro manual box.
I found some measurements online and it looks like the column shaft is pushed in about 1/4". |
03-30-2017, 12:24 PM | #8 |
Liked 72 Times in 40 Posts
When I switched over to a manual box from another Camaro, I believe I had to change the rag joint. But I dont recall a gap.
From rockauto.com: LARES 200 New; 3.25" OD Info For 3/4" 25 spline input shafts with flat and 3-1/4" OD steering coupling assembly. LARES 201 New; For 13/16" 31 spline input shafts with flat and 3-1/4" OD coupler. Info LARES 202 New; For 3/4" 36 spline full round input shafts with 3-1/4" OD coupler. Info Clark |
03-30-2017, 01:15 PM | #9 |
Liked 8 Times in 3 Posts
It's the Lares 202 , just did this on my car
03-30-2017, 01:19 PM | #10 |
Liked 221 Times in 102 Posts
Thanks for all this information . I didn't know the difference was in the rag joint . I have always gotten a manual box with the joint on it , so everything fit .
