05-26-2016, 08:58 PM | #1 |
Liked 287 Times in 77 Posts
Apd throttle stop problem
Has anyone running this set up had issues with the stop being inconsistent coming on?? Seems the first couple times I cycle the stop it hangs up closing then seems fine for a few hits then will hang up again... I have changed the solenoid & distribution block and it still does it.
05-28-2016, 06:28 AM | #2 |
Liked 17 Times in 9 Posts
Re: Apd throttle stop problem
I have installed the Max Speed carbs on 5 different cars. I also have them on two of my own cars and have never seen this. I'm sure you've already checked the basics:
Is anything binding? Is it hitting a SLE? Good CO2 bottle pressure? I wouldn't hesitate to call the guys at APD. I bet I've made a dozen calls there with some really dumb questions, and they've always been great to work with. Good luck, and let us know what you find out to be the problem. |
05-28-2016, 08:25 AM | #3 |
Ended up putting a few drops of air tool oil in the small adjusters on the ram and it seemed to solve the problem
05-28-2016, 08:40 AM | #4 |
Actually it wasn't that it was hanging up....The first few hits were normal then it would slam closed at full speed several times then normal intermittently.There must have been a dried out o ring in the adjuster.
05-30-2016, 07:20 AM | #5 |
Glad to hear you found the problem. Good luck with it, I have had great luck with them!
