10-30-2020, 06:19 PM | #1 |
Liked 236 Times in 89 Posts
200 metric issue
Ok, I figured since I am a master GM tech i would try my hand at checking why my metric lost 2nd gear. It had a high gear flare as well which could have been the eshift. Going manual valve body because the other wasn't legal but it was in it when i got it. Now, definitely steel metal in pan verified by a magnet. 3rd(direct) clutches are burnt but everything else looks ok. Also only 4 frictions in forward clutch, 2 in reverse. Band looked ok and billet pin isnt broken
10-30-2020, 06:20 PM | #2 |
Liked 761 Times in 225 Posts
Re: 200 metric issue
How's the sprag?
"That'll never work....." |
10-30-2020, 06:36 PM | #3 |
Alan, its fine. Spins one way, doesn't the other. I think converter may be trash too. Not really finding anything steel in trans damaged. Drum(not aluminum)has been banged pretty good(the 4 tangs) by a previous sunshell but the current shell looks new.
10-30-2020, 09:47 PM | #4 |
Liked 4,411 Times in 1,682 Posts
Jamie, What kind of servo? How much band clearance?
I would say, if the direct drum and the band is not burned, and everything else is intact, then the band is not applying.So now you've got to check the circuitry and fluid to the servo. I see the 3rd gear deal as a separate issue. We'll deal with that later. Who built this unit? You're putting a TA valve body back in it? *** Is the band anchor pin intact? Not sheared off?
We are lucky we don't get as much Government as we pay for..... Will Rogers Last edited by Mark Yacavone; 10-30-2020 at 09:55 PM. |
10-31-2020, 05:40 PM | #5 |
I did not measure anything before I unstacked it. Assumed with steel in the pan it was gonna be bad. Anchor pin is good. Going with a Sepanek manual valve body. Its going to my trans guy now. Next question. Should you have to put 3 washers(stacked together) between the converter and flexplate? Thats how it was when I got it. I'm guessing mabye 1/8" worth of shim. I feel it is really close to being bottomed out in pump.
10-31-2020, 06:01 PM | #6 |
Liked 129 Times in 59 Posts
Jamie,
1/8 inch sounds like the thickness of a motor plate. Did you try removing the washers and checking for converter hub engagement?
Lew Silverman #2070 "The Wagon Master" N/SA |
11-01-2020, 09:26 AM | #7 | |
Liked 819 Times in 263 Posts
11-05-2020, 10:37 AM | #8 |
Liked 242 Times in 72 Posts
with the converter unbolted and pushed into the trans until it is bottomed out, you need 1/8 inch (.125) space between converter mounts and flexplate. In other words, converter mounted up needs 1/8 (.125) from being bottomed out in the trans.
Mike Moller NHRA 203 Q-R-T/SA Last edited by MikeMoller; 11-05-2020 at 10:40 AM. |
11-05-2020, 01:04 PM | #9 |
Low volume pumps sometimes require less than .125
11-05-2020, 09:18 PM | #10 | |
Liked 388 Times in 82 Posts
