10-07-2015, 11:13 AM | #1 |
Liked 35 Times in 13 Posts
Head gasket bore vs compression
How important is the bore size of the cylinder vs the bore size of the gasket? Say you have a 4.200 bore and a 4.400 gasket what would be the difference in compression if I went to a 4.250 gasket?
10-07-2015, 11:19 AM | #2 |
Liked 236 Times in 127 Posts
Re: Head gasket bore vs compression
There are a lot of variables in CR. Try putting the info you are playing with into a calculator like the one in the link below to see the differences.
http://www.csgnetwork.com/compcalc.html Dale
10-07-2015, 12:48 PM | #3 |
Liked 142 Times in 64 Posts
Gasket bore size doesn't change compression as much as you think, thickness does.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
10-07-2015, 09:49 PM | #4 |
Considering an 0.040 gasket, the 4.4 would create a cylinder with a volume of 9.963cc while the 4.250 bore would give a cylinder of 9.291cc.
That's a 0.672cc difference. I don't think it matters a gnats eyelash. Dale
10-07-2015, 11:15 PM | #5 |
Would a 3.5cc decrease by using a thinner/smaller bore gasket make much difference? .012" thinner, about .030 smaller bore if i remember correctly. Worth changing?
10-07-2015, 11:42 PM | #6 | |
Liked 4,453 Times in 1,694 Posts
Worth changing? That depends on whether you consider this work...or fun.
We are lucky we don't get as much Government as we pay for..... Will Rogers |
10-08-2015, 12:14 AM | #7 |
It's certainly a lot of both....but sometimes i wonder . Thanks
10-08-2015, 08:06 PM | #8 | |
Liked 26 Times in 15 Posts
You have to be careful with this. Depending on how much chamfer your machinist put on the tops of the bores you could start hanging the gasket into the chamfer area. I put very little chamfer on performance builds but some guys might put more. All it takes is 030" all the way around and you will be into the fire ring on a 4.250 gasket and that's assuming that all of the bore centers, dowel pin holes etc. are perfectly aligned with the gasket. 4.250 should be safe but its just something else you need to look at.
Bill Koustenis |
10-09-2015, 03:30 AM | #9 |
Liked 1,809 Times in 572 Posts
I agree with Dale........Tiny change in compression for bore size variation.
