01-20-2021, 06:36 PM | #1 |
chev 305 dish piston eng.
need to find out what valve spring seat pressure should be.
checking mine with moroso guage was 220 was thinking they should be 180. .357 / 390 lift. any help anybody. thanks |
01-20-2021, 07:21 PM | #2 |
Liked 169 Times in 52 Posts
Re: chev 305 dish piston eng.
Leon, unless you're running coated lifters and a billet camshaft I wouldn't go over 180 on seat. I've never been able to run 200 on seat without wiping out lobes, and Ive tried all the usual lifter combinations ( hole in bottom of lifters different oils and lubes)etc etc. The tool steel lifters with a nitrided cam is what I use at 180 / 360.hope this helps.
Bill Bogues 4696 STK |
01-20-2021, 07:25 PM | #3 |
Liked 247 Times in 106 Posts
I would strongly recommend removing a spring, verifying the installed height, and then getting it checked with a Rimac (or similar) spring tester. The Moroso unit will vary depending on rockers, among other things. It's best used to check to see that all springs are equal.
Phil Molski S/C 1623 |
01-22-2021, 01:00 PM | #4 |
Liked 37 Times in 8 Posts
190 on the seat with Smith lifters. (I use the same 305 engine combo). No problems, just check them lifter pucks regularly.
Reggie Winkles 2650/Stock |
