08-28-2014, 10:26 AM | #21 |
Liked 5 Times in 3 Posts
Re: 1957 chevy in stock
So I assume I would not be allowed to install a crossmember, but would need to fabricate a side mount setup.?
Joe Keightley Pacific Junction Iowa |
08-28-2014, 01:32 PM | #22 | |
Liked 4,419 Times in 1,683 Posts
The front mounts are far enough apart to hold it in place. Not exactly the same as the early Corvette, but similar. You could add a torque strap , and I believe it would be fine. The early Pontiac was a bit different. It was a horseshoe deal with a center pad. That wouldn't work without bell housing or side mounts.
We are lucky we don't get as much Government as we pay for..... Will Rogers |
08-28-2014, 03:03 PM | #23 |
Liked 129 Times in 38 Posts
I think the question kind of boils down to: Can you legally install side motor mounts on a Tri-Five Chevy for stock eliminator?
08-28-2014, 04:02 PM | #24 |
Jimmy, You and I wouldn't get away with it..Maybe someone else would.
08-28-2014, 09:46 PM | #25 |
Liked 217 Times in 104 Posts
Thank You, Mark. I don't think I would be comfortable with that long distance between mounts on the Chevy, but somebody must be running it that way. Yes the Pontiac had one mount @ the front & it was bolted to an iron timing chain cover.
Dave Noll, E/FS ,L/SA 6526 |
08-28-2014, 10:07 PM | #26 |
I ran SS back in the 70's with my old 57 wagon, (Still got it, turned it into a street car). I used the old '57 265 block, so it didn't have the side mounts on the block, and I had an aluminum Powerglide transmission. I made a rear crossmember, and fabricated a drivers side torque arm that bolted to the bellhousing and had a mount on the frame with a rubber cushion between them. Worked fine with a small engine/low hp.
08-29-2014, 03:55 PM | #27 |
A mid plate to use stock type frame mounts?
08-29-2014, 05:14 PM | #28 |
Not necessarily the best, but the idea may work in low hp setup.
http://www.chevyclassicsclub.com/wp-...Chevy_tech.pdf |
