Old 04-25-2016, 05:44 PM   #1
evan701sg
Default Using throttle stop and starting line enhancer
Can you use a starting line enhancer and throttle stop during a run? I want to get 9.90 info this weekend while running Super Pro and would like to have a starting line enhancer for top bulb. I have a Dedenbear ts6 throttle stop (co2) with Lightning delay box. I also shift on time.
thank you in advance
evan701sg is offline   Reply With Quote
Old 04-25-2016, 08:05 PM   #2
Rick Blake
Rick Blake's Avatar
Default Re: Using throttle stop and starting line enhancer
Yes
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 04-26-2016, 11:39 AM   #3
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
I always use my starting line enhancer when running Super Comp. Stage with my foot to the floor, and the car goes to WOT as soon as I set the transbrake.
You need to change the enhancer setting to make it work that way instead of going WOT 0.8 or 1 second before transbrake release, as it does while bracket racing.
At any rate, yes, you can use both on a run.
S/ST 51
S/C 53
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
