Old 10-01-2008, 12:14 AM   #1
FED 387
Liked 333 Times in 180 Posts
Question using a bandsaw to cut aluminum etc
Anybody know ????----Have the use of a bandsaw for free however it has only been used to do woodworking projects---The blade speed is NOT adjustable one speed-----With the correct metal cutting blade can I cut thin aluminum under 1/4 to 3/8 inch or thin steel under 3/16 inch to make some pieces for tabs -brackets etc without ruining the saw??? Thanx Comp387
Old 10-01-2008, 01:30 AM   #2
larry dowty
Liked 11 Times in 4 Posts
Default Re: using a bandsaw to cut aluminum etc
Try and change the pulley on the motor if you can, try and slow it down, i did the same thing to mine get a bi-metal blade workes ok for home use 3/8 alum is about all it will want.
larry dowty is offline   Reply With Quote
Old 10-01-2008, 07:27 AM   #3
Larry Munk
Circular saw with a fine tooth carbide blade will handle the aluminum. You will need a gear drive saw for over 1/2" or so aluminum. Variable speed sawzall with a fine tooth blade for the steel. Works for me.
Larry Munk is offline   Reply With Quote
Old 10-01-2008, 07:28 AM   #4
Larry Munk
Oh and a GOOD pair of saftey googles and a face shield.
Old 10-01-2008, 07:33 AM   #5
bobby
bobby's Avatar
Actually, aluminum is more forgiving thatn steel. You can run the blade at just about any speed you want. Use WD40 to keep the blade from loading up with shavings. When you cut steel, you need to slow the blade speed down.
bobby is offline   Reply With Quote
Old 10-01-2008, 09:07 AM   #6
FED 387
thanx for the replies kinda what I was thinking too--Comp387
