Old 04-16-2009, 09:33 AM   #1
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Default Trailer tire info
An aquaintance sent me this trailer tire info so I thought I would pass it along to others. Anyone who can add other tips, please do.
Trailer Tire Applications· Trailer tires are designed for use on trailer axle positions only, not for the loads applied to or the traction required by drive or steering axles.
· An “LT” designation on a trailer tire size specifies load range only. It is not designed for use on light trucks.
· Do not mount “ST” or “LT” trailer tires on passenger cars or light trucks.
· Always inflate trailer tires to the maximum inflation indicated on the sidewall.
· Check inflation when the tires are cool and have not been exposed to the sun.
· If the tires are hot to the touch from operation, add 3 psi to the max inflation.
· Underinflation is the number 1 cause of trailer tire failure.
Speed· All “ST” tires have a maximum speed rating of 65 MPH.
· As heat builds up, the tire’s structure starts to disintegrate and weaken.
· The load carrying capacity gradually decreases as the heat and stresses generated by higher speed increases.
Time
· In about three years roughly one third of the tire’s strength is gone.
· Three to five years is the projected life of a normal trailer tire.
· It is suggested that trailer tires be replaced after 3 to 4 years of service regardless of tread depth or tire appearance.
Mileage
· Trailer tires are not designed to wear out.
· The life of a trailer tire is limited by time and duty cycles.
· The mileage expectation of a trailer tire would be 5,000 to 12,000 miles.
Why Use An “ST” Tire
· “ST” tires feature materials and construction to meet the higher load requirements and demands of trailering.
· The polyester cords are bigger than they would be for a comparable “P” or “LT” tire.
· The steel cords have a larger diameter and greater tensile strength to meet the additional load requirements.
· “ST” tire rubber compounds contain more chemicals to resist weather and ozone cracking.
Storage
· The ideal storage is in a cool dark, garage at maximum inflation.
· Use tire covers to protect the tires from direct sunlight.
· Use thin plywood sections between the tire and the pavement.
· For long term storage, put the trailer on blocks to take the weight of the tires, lower the air pressure and cover tires to protect from direct sunlight.
Maintenance
· Clean the tires using mild soap and water.
· Do not use tire-care products containing alcohol or petroleum distillates.
· Inspect for any cuts, snags, bulges or punctures.
· Check the inflation before towing and again before the return trip.
Three keys To Avoid Trouble
· Make sure your rig is equipped with the proper tires.
· Maintain the tires meticulously.
· Replace trailer tires every 3 to 5 years, whether they look worn or not.
Travis Miller is offline   Reply With Quote
Old 04-16-2009, 09:55 AM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Trailer tire info
Nice information. More from the School of Hard Knocks and Blowouts on the Side of the Road. There is no such thing as a good 15" trailer tire. ST tires are junk no matter the brand. 16" rims & 10 ply commercial tires work fine on a 2 axle trailer. There are 6 hole 16" rims available reasonable. 3 Axle trailers (Stackers) blow 16" tires. (Alcoa now makes a direct replacement 17.5 rim for the 7000 lb axle, and Continental makes a 17.5 tires that is rated @ 3600 lbs per tire) Commercial tires are made for about 3 years service. A big truck tire ( motor home or conversion) cannot be recapped no matter how new looking after 3 years. ( I just changed 10 @ $375 each that looked brand new) We do have just a little experience with tires as we have 1600 leased trucks that we provide tires for. We blew so many 16 in tires on my stacker, we could change one on the side of the road faster than Nascar, and we carried 3 spares and sometime that wasn't enough. These were all Goodyears 16 plys. They work great on 2 axles, too much wiggle on 3 axles. This information is from the people who service our fleet.
Jeff Teuton 4022 STK
Old 04-16-2009, 10:18 AM   #3
Travis Miller
Now I understand Jeff. My info applies to smaller trailers. Your info applies to REAL TRAILERS. LOL Maybe some of the basics will still be useful.
Old 04-16-2009, 10:35 AM   #4
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Trailer tire info
Travis,
Hope you are doing well... Thanks, for the great info on trailer tires.... Us racers do really appreciate the extra effort you give the racers....
Dave Ribeiro 1033 STK
Old 04-16-2009, 10:57 AM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
I would not recomend 16 inch Mission tires either. We installed a bunch of them on all differnt kinds of trailers around here, they came on my Haulmark GN as well and did not seem to be having problems. Well coming back from Tulsa a couple of weeks ago belts broke in 2 of them. Got to calling around and I guess they are referred to as "China Bombs" now. Tried to get a couple more so all tires would match and found out the ones I have are no longer being sold in the US and the ones that took their place are worse sometimes letting go in as few as 1500-2000 highway miles and causing major damage when they do. Warehouse that I get my tires from recomended I get them off my trailer as they are a problem waiting to happen and if I had any 15" to stop using ASAP. I am trying to find out if their is any warranty or recall help but so far no luck. Haulmark claims they have not used them in several years but my trailer is only 2 years old and it came with them. If I find out any more I will forward it along as I am sure there are a bunch of guys here with haulmarks.
Old 04-16-2009, 12:53 PM   #6
Bernie Cunningham
Liked 52 Times in 17 Posts
If I could, I'd like to recommend a great 16" trailer tire that I use on my 50' long trailer. Yes those Goodyear G614 are real bad news and were expensive.
Bridgestone R250, DURAVISS, they are modeled after a larger truck tire and have really stiff sidewalls.
B
Bernie Cunningham 7053 STK
Bernie Cunningham is online now   Reply With Quote
Old 04-16-2009, 02:09 PM   #7
Jeff Teuton
Bernie, are the Bridgestones the 235/85/R16 tires? We use lots of Bridgestone and have found them better than other brands for wear. I didn't know they made a smaller tire.
Old 04-16-2009, 05:20 PM   #8
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Trailer tire info
Hey Bernie!
Do you have to get those tires shipped in from Perth?
G-Day Mate, All Right Are Ya?
Cimo
Jim Cimarolli is offline   Reply With Quote
Old 04-16-2009, 08:07 PM   #9
Ron Brown
Ron Brown's Avatar
Rob, The trouble with getting Haulmark to do anything is that alot of their dealers switch around wheels and tires to accomadate customers and it is possible that that happen to you. It happen to me and my dealer tried to pass it off on Haulmark, I trold him I saw his guys take them off of his stockroom floor and put 'em on my unit. At that point he sucked it up and replaced the two tires and nice rims.
Ron Brown
be back soon
Ron Brown is offline   Reply With Quote
Old 04-16-2009, 08:38 PM   #10
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
I have a 30' living quarters trailer and during a trip to the Indy Nationals in 2007 I blew out three 16" tires. On this trip I replaced all four tires. During the trip to the 2008 Indy Nationals I blew out another three tires. I can tell you they only had about 2500 miles on them. One of the 16" tires blew out while I was attending a race at Houston Raceway Park. The trailer was parked in the track for a day and we heard a loud boom! I then discovered one of the new tires, I had just bought several weeks ago blew out. That was it!! Thanks to the help of Jeff Teuton, I bought a set of 17.5 Alcoa Aluminum wheels and 17.5 Continental tires. My old tires required 80 pounds. The new tires require 125 pounds of air. No more blow outs and the trailer handles much better without swaying. If I go to the 2009 Indy Nationals, I am sure my tire problems are over. Thanks Jeff! Yea we were pretty good at changing the tires on the side of the highway.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
