Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 02-27-2010, 08:24 PM   #1
rod
Liked 20 Times in 15 Posts
Default air entry base plate?
what is the best air cleaner [i use a 6 high x 14 dia always] base to use to get the most air into a Holley? i have both stock choke horn and milled carbs.
i have these 3 items to choose from; a 15x15 flat plate and cut up factory ford with a very nice radius into the carb. [especially the milled one]. and a K&N stub stack.
i do not have a hood scoop [don't want one] and i know no base is not good.
thanks rod
rod is offline   Reply With Quote
Old 03-06-2010, 05:17 AM   #2
68camaroSS
Default Re: air entry base plate?
I read somewhere that the sub-stack will in some cases actually hurt performance, also jetting changes may need to be made. I was going to try one some time ago until I research it, and decided against it.
68camaroSS is offline   Reply With Quote
Old 10-30-2010, 08:57 AM   #3
nickh
nickh's Avatar
Liked 644 Times in 193 Posts
Rod,
Sent you a PM
