Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 08-23-2011, 01:18 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Rev limiters / launch
I figured either Comp or Pro Stock guys would have the best answer for this.........Super Stock guys , please answer if you use manual trans.
Mostly for the manual trans guys................what are you using for an RPM limiting device at launch? 2 step , or is there something "easier" on the engine / better to use?
The point I 'm trying to get an answer for is that either they ( Pro Stock , etc ) launch at such a high RPM the engine "sounds" smoother or they are using a different device..............which is it?
Old 08-23-2011, 01:45 PM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: Rev limiters / launch
We use a MSD 2-step on our super stock stick car. The higher the RPM's the smoother it sounds, at least on our car. 7k you here the 2-step, 8k not as much, 9k you don't hear it. Hope this helps some.
Robert
Robert Simpson is offline   Reply With Quote
Old 08-23-2011, 01:49 PM   #3
joespanova
Robert
OK , yeah that helps. I leave at 7000 and you definately hear it..........a sound I dont like.
Old 08-26-2011, 08:08 AM   #4
joespanova
I just want to add........
it appears the digital ignitions are in fact "smoother" than the old analog........but most of you already knew that didnt you........
