Old 06-01-2011, 12:09 AM   #1
gearjammer
gearjammer's Avatar
Send a message via AIM to gearjammer Send a message via MSN to gearjammer
Default 1972 Nova Street Strip .....FS OR Trade....
1972 Nova Street Strip Buildup
$11,000.00 cash OR
$9,000.00 cash & a SBC w/ 350 TURBO (for a street rod)
-Front Suspension-
Stock OEM Sub-Frame
OEM Control Arms
AFCO Low friction upper and lower ball joints
AFCO Low friction bushings
Moroso Trick coil springs (uncut)
Lakewood 90/10 (QA1 Stocker Star R Drag Shocks New in box)
OEM manual steering gear box
Wilwood Disc brakes
-Rear Suspension-
9" large tube and ends w/ backbrace
"N" case
Summers Brothers custom scolleped 35 spline spool
Moser 35 spline axles
4.57 ring n pinion
1350 U-joints
Calvert split mono leaf springs
Caltracs
Rancho X9000 9 way adjustable shocks mounted inboard
AFCO leaf spring sliders
Anti roll bar
Large Ford drum brakes
-Body and Chassis-
Fiberglass front bumper
Fiberglass 4" cowl Harwood bolt on hood
Steel body
New carpet w/ backing removed
Steel rear bumper
Jaz poly seats (2)
RJS 5 point harnesses
OEM rear seat w/ modified frame to clear mini tubs
10 point roll cage with swing out door bars
CE weld in frame connectors w/ leaf spring pockets
Rear mini tubs
Tires and Wheels-
Front Weld Draglite 15x4 w/ 2 1/4" backspace
Front Tires MT 15x29x7.6
Rear Weld Draglite 15x10 w/ 51/2" backspace screwed
Rear MT 30x9 ET Drag Radial Slicks
-Tranmission-
Hutch built Glide w/ 1.76 1st. gear w/ pro brake
ATI 8" 4500 stall converter
B&M Pro Stick
B&M large cooler
31/2" Aluminum driveshaft w/ 1350 u-joints
-Fuel System-
16 gallon Jaz poly fuel cell
Jegs -10 in-line billet fuel filter
Aeromotive Street/Strip 150 ghp fuel pump
-8 fuel line
Aeromotive Universal Bypass regulator
-Current Power Plant-
460 cubic inch BBC
TRW 43 cc dome pistons
GM steel rods w/ ARP bolts
GM steel crank .010/.010
Scotty Brown custom solid camshaft .636/.595 256/266 @.050 ICL 108
Solid lifters w/ EDM oiling
Milodon 8qt. oil pan kit
TCI balancer
063 Closed Chamber heads 101 cc w/ small valves
Valve springs matched to cam
Comp cams stainless roller rockers w/ poly locks
Fabricated valve covers
Team G 4150 intake uncut
Proform 850 race carb
MSD Billet Distributor w/ bronze gear
2" primary tube Hooker headers
3" "X" flow exhaust system into 31/2" Borla XR1 stainless mufflers
Current weight 3,471 lbs
Contact information
day prowe@tweddle.com
nite gearjammer@wowway.com
248-219-3118 please leave a message if I can't answer and I WILL return your call aas soon as possible
Thanks for looking
http://i49.photobucket.com/albums/f2...072Nova008.jpg
http://i49.photobucket.com/albums/f2...072Nova006.jpg
http://i49.photobucket.com/albums/f2...1014000940.jpg
http://i49.photobucket.com/albums/f2..._p5RKV-M-2.jpg
http://i49.photobucket.com/albums/f2...ngine001-1.jpg
http://i49.photobucket.com/albums/f2...43_shNe8-L.jpg
Phil
JPR Motorsports
1972 Nova Street Strip Project
gearjammer is offline   Reply With Quote
