Go Back   CLASS RACER FORUM > Class Racer Forums > Top Sportsman and Top Dragster
Old 09-13-2012, 09:16 PM   #1
rognelson777
Liked 135 Times in 74 Posts
Default tire shake question
6.60 Comp eliminator dragster 200 mph 1.000 60 ft times 14 wide tires, solid rear 240inch car 1600lbs tire shake later in the day at LODRS englishtown, 1st 3 rounds eliminations not a problem .
any ideas? tire pressure up/down leave softer harder or was it just the track that day?
rognelson777 is offline   Reply With Quote
Old 09-17-2012, 05:12 PM   #2
JR fuel
Default Re: tire shake question
My car is not as quick as yours it's a 7.00 smallblock but I have had this happen to me at the Lebanon divisional . The first time it shook it was right at the hit . The car dead hooked and shook real bad . So we tried raising the air pressure from 6 and a half to 7 lbs . The next pass it spun and then it shook . I really think raising the tire pressure helped but when we made the second run it was right after the alcohol cars ran . I think that the alcohol cars actually tear up the rubber on the track . The next day the car went right down no shake at all . Next race at Epping not one problem with shake tires at 7lbs. I run the 12x33 Goodyears on mine
JR fuel is offline   Reply With Quote
Old 09-22-2012, 11:33 PM   #3
rognelson777
Thanks for info we were talking about raising tire pressure when track cools or gets sticky. Will let you know
Old 09-23-2012, 12:55 PM   #4
JR fuel
Are you going to the Dutch ? It should be fast Hoping to get my first 6 second run there .
Old 09-26-2012, 12:01 AM   #5
rognelson777
Registered for nationals at the grove and if all goes well will also be at the dutch
