Old 08-23-2012, 10:18 AM   #1
peter kivett
Default Stocker Motor for sale - 350 c.i. 300hp combination sbc
For Sale Stocker Motor - 350 c.i. 300hp combination small block Chevy $4500.00 obo
(I have records for all dyno pulls on Burtonsville machine dyno)
Best ET at legal weight & motor for a 1969 Nova in G/SA was 11.485 @115.6 mph (36 runs on motor short shifting in bracket mode 95% of the time)
• 292 casting heads prepped by Burtonsville machine
Hollow stem Ferrea valves
Burtonsville valve job
Crane harden rockers
ARP pro series rocker studs
Psi springs
GM light weight retainers
Harden locks
*To be noted (no acid porting) plenty of potential left within these heads
• Intake
NO acid porting or intake modification
Carb pad resurfaced
Intake flats resurfaced
*I have another intake that has a lot of work done to it, it’s almost two tenths faster than the stock intake / modified intake was not dyno with motor
• Short block
010 GM casting bored .060 over
Decked
Lined honed
Coated cam bearings
• Valve train
Bullet Cams
Burtonsville proprietary grind
Smiths Machine lifters
• Pistons
CP pistons
Coated (Swain Tech Coatings)
Full floating
Precision Products wrist pins
Burtonsville Machine special gapless ring package
• Crank
Reground to maximum allowed offset (per NHRA rule)
Fluid dampener (sfi approved)
• Bearings/Gaskets
Calico bearings
One piece Felpro oil pans gasket
Felpro head/intake gaskets
• Corvette oil pan
Oil pump highly modified
• Leon Miranian prepped Q – Jet
Contact Peter Kivett @ 443.306.3583 at any time. (please leave a message if I can't answer the phone)
peter kivett is offline   Reply With Quote
Old 01-19-2013, 08:03 PM   #2
mcashman
Liked 6 Times in 3 Posts
Default Re: Stocker Motor for sale - 350 c.i. 300hp combination sbc
U still have motor or any parts for sale?
mcashman is offline   Reply With Quote
