Old 04-02-2013, 11:10 AM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question 455 OLDS WILL NOT START Q-jet
My friend has a 1969 442 olds ( all original and restored)
that will not start after sitting for 3 days.
Dump some gas in the carb and it will fire up and run.
It will restart again for 2 days
but on the 3rd day it will not start without dumping gas in the carb.
He has to crank on it and crank on it and it will not get gas up to the carb.
We tried a filter with a check valve (stock style in the carb inlet) that didn't work.
I think it's the fuel pump.
What do you guys think.
MEXJOE is offline   Reply With Quote
Old 04-02-2013, 12:47 PM   #2
Chuck Garey
Liked 10 Times in 7 Posts
Default Re: 455 OLDS WILL NOT START Q-jet
Pull the base off and check the wells for the primarys, these are notorious for leaking down over time. A little epoxy will do the trick
Chuck Garey is offline   Reply With Quote
Old 04-02-2013, 12:56 PM   #3
Jim Kaekel
Liked 531 Times in 108 Posts
X2 what Chuck said. I would also check to be sure that the fuel lines from the pump to the fuel tank are in good shape. Rusted-thru, cracked or a leaking line could cause similar problems.
Jim Kaekel 3836 STK
Old 04-02-2013, 12:57 PM   #4
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Most of the Q-jet rebuild kits come with a two-part epoxy and plugs to replace the factory main well plugs which, as Chuck mentioned, are notorious for loosening over the years and causing just the problem your friend is experiencing.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 04-02-2013, 12:58 PM   #5
rx dealer
Liked 53 Times in 13 Posts
Does this car has a return gas line to the fuel tank? I have an all original 69 camaro with the original 350-300hp and original Q-Jet with the factory style external fuel filter that has a return fuel line and it will not start easy after sitting for a while. It does the same as you describe. I have taken the carb apart after its been sitting for a while and the fuel bowl is bone dry. I don't use the small fuel filter in the carb only the factory external inline filter with the built in return line....Luke
rx dealer is offline   Reply With Quote
Old 04-02-2013, 02:05 PM   #6
ron mattson
Liked 67 Times in 30 Posts
sounds like the well plugs to me!
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 04-02-2013, 03:31 PM   #7
MEXJOE
MEXJOE's Avatar
OK
But if it was the main well plugs, why would the pump be dry? He has to crank this thing for a LONG time and it gets no gas to the carb when you push the accelerator pump down nothing comes out, even after cranking for a long time, so long in fact he ran the battery dead.
I need to see if he has a return line or not.
I haven't seen the car yet.
I will J-B WELD the main wells. Also I'm gong to look and see if it has a "windowed" needle and seat. I remember reading someplace that can cause it to leak back as well.
Thanks for the Ideas!!!
HOOO YA Just for the record...
You have 37 days before BIR opener!
GLEN
Old 04-02-2013, 04:31 PM   #8
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Dave Noll, EF/S ,?/SA 6526
Old 04-02-2013, 04:58 PM   #9
Lyn Smith
Liked 967 Times in 194 Posts
Fuel filter in the tank clogged,or collapsed.Wont pass enough fuel unless the engine is cranking over?
Old 04-02-2013, 08:16 PM   #10
MEXJOE
MEXJOE's Avatar
THANKS!!
WE ARE GOING TO PULL THE TANK AN CHECK THE PICKUP.
He got a new fuel pump as well and it HAS the return system on the pump.
KEEP THE IDEAS COMING!
THANKS TO ALL FOR THE TIME AND KNOWLEDGE!!!
GLEN
