Old 04-17-2017, 11:01 PM   #1
5389stk
Liked 75 Times in 7 Posts
Default misc parts chevy
sbc 10 stocker block .060 , 9.00 deck height ,bushed lifters, 4 bolt main, arp bolts , filled to water pump holes . good block switch to dart 300.00 can bring to Chicago points meet . 218-357-3701 days 218-644- 3337 evening calls only [ sold ]
k900 valve springs new 180.00
k900 outers only new 75.00
bbc main spacers 409 crank to bbc block 100.00 sold
arp head studs used 75.00
turbo action shifter reverse pattern gm used 100.00 ,[218-357-3701]
3100 arc 6 switch panel used 40.00 sold
bbc main studs 2 bolt used 40.00
DLC coated bbc 990 x .155 wall x 2.75 tool steel pins 80.00
8 comp .135 wall x3/8 x9.125 pushrods used 40.00
8 comp .135 x3/8x 8.125 pushrods used 40.00
16 3/8 x 7.90 x .080 used 40.00
5389stk is offline   Reply With Quote
Old 04-18-2017, 08:24 AM   #2
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: misc parts chevy
Check your PM. Would like to purchase 409 Main Bearing spacers. Thank you…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
