1. Chev 350/300 HP S/S Motor
GM Stock filled block 4.070 Bore Gm Forged Crank Bullet Cam 276/283-04 Stock Bearings Manley Rods 186 Ported Heads non Welded & Raised EX Ports ARP Head Studs New Manley Valves 200" Long CP Pistons Comp Cam Belt Drive ATI Balancer Jessel Shaft Rockers 1.8 INT 1.6 EX Victor E Intake Epoxy Matched to heads Moroso Oil Pan W/ Heat Pad MSD Crank fired ignition $ 8,000 Fresh Off Dyno 2. Chev 350/300 HP S/S Motor Bowtie Block 4.060 Bore Scat F43 Lightweight Crank 1.888 Manley Tour Lite Honda Rods 1.888 CP Pistons .027 Rings ATI Balancer Comp Belt Drive Jessel Shaft Rockers 1.8 INT 1.6 EX Comp Cam 276/284-107 Stock Bearings MSD Crank fired ignition ARP Head Studs New 041 Voges Heads Ferrea Valves Pac Springs Super Victor Intake Voges Moroso Oil Pan w/ Heat Pad $ 14,000 Fresh Dyno Time Only sold 3. 9" Ford Strange Aluminum Center Section w/ Carrier box 40 Spline Spool 6.0 Richmond 9310 Pro Gear 1350 yoke Perfect condition 40 Runs $ 1,000 sold 4. 9" Ford Strange Aluminum Center Section 40 Spline Spool 6.20 Richmond/Gleason Pro Gear 1350 yoke Perfect condition 30 Runs $ 1,000 sold 5. 9" Ford Dewco Aluminum Center Section w/ Aluminum Carrier Box 6.0 Lightened Pro Gear Richmond/ Draw Through Carrier Bolts 40 Spline Spool 1350 yoke Perfect condition 25 Runs $ 1,500 6. Jerico DR-4 Trans w/ Long Shifter- T handle 18 spline 1st 3.19 2nd 2.00 3rd 1.39 4th 1.0 Perfect Condition No Issues $ 2,500 sold 7. 9" Ford Ring & Pinion 6.20 Richmond/Gleason Lightened Pro Gear Perfect Condition $ 250 sold 8. McLeod Clutch Set up / Black Magic Rebuilt 18 spline 10-1/2 Aluminum Flywheel/ Pressure plate & disk w/ T.O Bearing Fresh 0 Runs $ 1,500 9. Q-Jet Race Carb 7029207 Good Condition $ 100 sold 10. Q-Jet Headworth Race Carb 7029207 Good Condition $ 400 sold Contact Gary 801-969-9052 Email gary7525ssh@gmail.com Last edited by Bryan; 07-05-2021 at 07:36 PM. |
Liked 500 Times in 245 Posts
Email sent.
Liked 22 Times in 16 Posts
what input shaft is in the jerico
Email sent
#5 | |
