Old 11-24-2007, 11:49 AM   #1
RICK W
Default Oil Passing By Rings
350 Chev Ss With Venolia .060 Pistons. Have Used The R-9941 Ring Set For Years. Now Oil Is Going By The Rings Big Time. The Set Is .065 Over, File The Top Ring To Fit Cylinder And Install Oil Ring. The Piston Will Fit In The Bore With The Oil Ring On It Without A Ring Compressor. I Have Two Blocks, Measured The Cylinders Which Are Ok. Any Comments-thanks
RICK W is offline   Reply With Quote
