Thread Tools | Search this Thread | Display Modes |
***Gear Sets***
Strange Aluminum Carrier (Used) ***$950*** *40 Spline Strange Steel Spool (Used) *4.88 Pro Gears (Used) *Includes Shipping Container * Buyer Pays Shipping ***Ignition Boxes*** MSD 7530T Ignition box (Used) ***$390*** * Tested good from MSD * OE Harness and cable included ***Shocks and Springs*** Koni Electric Shocks ***$1000*** * Used 2010 to 2014 Season * GMM Air Sweeps * Gen 2 MSD Style Control Box * Comes with spring Bearings Eibach 2.5x14.00 200# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 200# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 225# Springs (Pair) Used ***$50*** Eibach 2.5x8.00 300# Springs (Pair) NEW! ***$50*** ***Engine Valve Springs*** PAC-1370L QTY 8 NEW! ***$300*** PAC-1355H QTY 13 NEW! ***$400*** ***TRE Tunnel Ram Dominators (Used) ***$1100*** * Holley 4500 Style * 1.83 Venturi * 2.125 Blades * Billet metering Blocks * Buyer Pays Shipping ***Engine Top End*** *2013 MBE Splayed Valve Cylinder Heads 16 Runs Last Freshened 04/2018 ***$7500*** *These are MBE/DART Casting, cast Heads. No GM Part Number *Xceledyne CRN Titanium Intake Valves *Victory DLC Titanium Exhaust Valves *Setup for PAC 1355H *Jesel Aluminum (solid body) Rocker Arm Set with hardware and Stands *2.0 Pivot Length *1.85 Intake Ratio *1.85 Exhaust Ratio (1.75 Ratio available as Option or in additon for extra $800) *Ball Type Adjuster *Needle Nose Bearings *-10 Vacuum Pump Connection *HRE Intake Manifold, Dual 4500 Top, includes drop-ins, Billet Runners, -12 Vacuum Pump connection, For 8.900 Deck. Last edited by 3354 C/AA; 04-08-2022 at 04:22 PM. Reason: Intake Sold |
Do you have any pics of the SB2 intake?
Intake is approximately 9in high. images are available.
I am interested. Can you send pics to 309-840-2198?
Liked 825 Times in 284 Posts
PM sent.
