Old 04-10-2024, 08:55 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Wanted: Set of usable pistons for mopar 318
going a differ combo
Old 04-10-2024, 10:53 PM   #2
GTX JOHN
Liked 2,490 Times in 700 Posts
Default Re: Wanted: Set of usable pistons for mopar 318
Are they flat top or with valve relief or either
way?
I never raced that year as I hate 2 Brl carbs.
John Irving
741 Stock
741 Super Stock
Old 04-11-2024, 12:07 AM   #3
David Lee
way?
yes, they are flat tops. but it seems the same pistion set can work from 68 to 88. if you pm your paypal amount, i will send the payment asap
Old 04-11-2024, 01:56 PM   #4
GTX JOHN
You are fine and can pay me when
I deliver them to you!
I am at Vegas races until after next week's
divisionals.
If you need them sooner = I can try to get home and
ship them to you after Nationals.
John Irving
741 Stock
741 Super Stock
Old 04-11-2024, 02:23 PM   #5
David Lee
divisionals.
when ever you get here will be good.
Old 04-11-2024, 07:38 PM   #6
GTX JOHN
I did some checking and the 68 to early 70s pistons have
4 VALVE notches similar to 72/73 340 engines.
You need to use them rather than flat tops or you will have
nearly zero valve clearance with a stocker camshaft with
correct lift.
Sorry I did not know the early engines had a different piston.
John Irving
741 Stock
741 Super Stock
Old 04-11-2024, 08:34 PM   #7
David Lee
[QUOTE=GTX JOHN;695987]I did some checking and the 68 to early 70s pistons have
correct lift.
Sorry I did not know the early engines had a different piston.[/QU
ok, guess i will just have to go with the ross pistons. the class whides to not mention the valve reliefs
