Old 04-01-2008, 09:04 PM   #1
J Kuchel
Banned
Question VP race fuels
I run a BBC that has 9.69 to 1 comp.. I have always used VP C-12 fuel but I don"t need all of the octane so, I was thinking of switching to VP Motorsport 105L fuel. It is suppose to be good to 11 to 1 comp.. It has a motor octane of 101 and a specific gravity of .745 - .760 @ 60 degrees F. Can someone tell me if this is a good choice? I like to stay with VP fuel. It is going to be for a bracket car.
J Kuchel is offline   Reply With Quote
Old 04-01-2008, 09:54 PM   #2
Caperat
Default Re: VP race fuels
Save your hard earned cash and run the rat on high test pump gas. I've played with the same combo and the blue barrel juice is a waste of money unless you want to run some spray.
Caperat is offline   Reply With Quote
Old 04-02-2008, 02:33 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: VP race fuels
I'd say sunoco ultra 94 would be fine! I ran cam2 in my old bracket car till one day I ran out in the 6th round of elim. all i had was generator gas ...put it in & the car broke out! it was a 9.5 comp. car.
Old 04-02-2008, 06:37 AM   #4
J Kuchel
Banned
Question Re: VP race fuels
Ok does the static comp. and the cranking comp. make that much difference? The static is 9.69 to 1 but it has alot of cranking comp. due to the camshaft profile.
Old 04-02-2008, 10:54 AM   #5
Dave Cook
Dave Cook's Avatar
If you spin it many RPM's, your octane requirement does go up, but I agree, you are probably wasting $$ and performance potential by running more octane than you need. Octane is, in simple terms, the measure of the resistance to ignition....if you are running race fuel in a low compression engine, you have to advance the timing to recover the performance you may get with lower octane and less ignition lead.
B.T.W., my engine is 15.01:1 static, with a fairly long duration flat tappet cam. I run any generic "110" leaded fuel that is available, but never spin it over 6500 RPM's, run it cool, (130 at the line) and run it fat on the carb jetting.
Dave Cook is offline   Reply With Quote
Old 04-02-2008, 12:06 PM   #6
ewgant01
C-11 might be a better choice. I'd call VP, they might know what would be your best choice.
ewgant01 is offline   Reply With Quote
Old 04-03-2008, 05:10 PM   #7
J Kuchel
Banned
I run the engine to 6500 rpm"s, so will a unleaded fuel work? I thought I had to use a leaded fuel.
Old 04-03-2008, 06:53 PM   #8
ewgant01
http://www.vpracingfuels.com/vp_01_fuels.html
that's VP's page listing their fuels and what they are best used in.
