Liked 5 Times in 3 Posts
my 04 mustang has a headlight that is "foggy" how can I fix it?
Liked 4 Times in 2 Posts
Probably got some moisture up inside it Greg. Get it dried out, and might have to silicone seal it. I know this is what we have had to do before on the Firebird tail lights.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
Try your local hobby shop for some plastic polish , Tamiya Finish Polish if they have it.
Bud Lefevre 3075 STK IHRA World Record Holder |
Greg,
Spend some of the money your wife saved on gas (with the Mini) and get a new one...................HA HA |
Liked 334 Times in 181 Posts
If the cloudiness is on the outside try TOOTHPASTE--It will do a great job too---takes a little while but just put it on and rub/buff it with a damp---NOT SOAKING WET cloth---any brand of toothpaste will work just use the stuff in a tube----Comp 387
Liked 51 Times in 14 Posts
Greg,
If i'ts on the outside you can recondition it with a headlamp reconditioning kit. You can most likely find one online. The brand we use is from Bright Solutions. Jeff Ross |
Liked 43 Times in 10 Posts
If the exterior surface of the headlight has yellowed, take a piece of 2000 grit sand paper and sand the plastic surface of the light. Then take Mequiers #2 rubbing compound and rub it out. You may have to do it twice. Then coat it with a good carnuba wax. I did it to my 94 Escort. It came out very nice.
Nelson Kowal Stock 345 |
