Old 05-26-2008, 10:49 PM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Air pressure for radials
What air pressure should I run in hoosier radial and/or goodyear radial.E/sa dodge demon. 3310 lbs. runs .7 under.it's a new car to me.any help would be great.
dartman is offline   Reply With Quote
Old 05-26-2008, 11:21 PM   #2
SSDiv6
Default Re: Air pressure for radials
I would start at 20 lbs. and start adjusting the pressure from there.
Old 05-27-2008, 08:17 AM   #3
dean ribeiro
Liked 239 Times in 79 Posts
I agree, start at 20 lbs. At a good track, with that much wieght, you should be able to run 22-24 lbs of air pressure. Each pound that you can put into a radial (without spinning) is usually worth .005-.008.
Dean
dean ribeiro is offline   Reply With Quote
Old 05-27-2008, 08:47 PM   #4
George Mirza
20 lbs always works best on my '71 Duster E/SA @ 3310#. Good luck with the new car, hopefully we'll cross paths sometime, maybe the North American Nationals at Epping.
George Mirza
George Mirza is offline   Reply With Quote
Old 05-28-2008, 06:26 AM   #5
dartman
dartman's Avatar
thanks for the info.see how it works on the weekend. I will be at Epping. see you there.
KELLY MACKAY
