We run our timing locked at 38 degrees. I have been told that if I retard the timing a couple of degrees at the end of the track after going into high gear the car should pick up.
I have always heard that you increase the timing at higher RPM to assure that the spark plug fires early enough to keep up with the increased piston speed. Can someone explain to me why retarding the timing a couple of degrees at the end of the track would help pick the ET up? |
#2 | |
Liked 880 Times in 311 Posts
You may have been told to retard the timing, but I think that is only part of what needs to be done. I got best results by advancing the timing when the engine was accelerating quicker(rate) in first & second. Then bring it back to the best power setting in 3 rd & 4 th. I've done the same with my old Modified cars & am doing something similar with my V-6 SS. It is quite a bit easier to do with all the electronics on the market today. I think there was an discussion on Speed Talk forum about required timing. You might do a search over there. Every combination is different, it takes testing. Study the incrementals.
Adger Smith (Former SS) Last edited by Adger Smith; 07-02-2008 at 10:32 PM. Reason: SP as usual |
