Liked 165 Times in 59 Posts
any one running a motorcraft 4300 carb,looking for some on set up any info would be helpful,tom thanks for you info thanks gmonde
Liked 57 Times in 33 Posts
i run the 4300D on my combo love it. back to back with dads 780 holley off his 71 runs the same..
Duane Eiskant 1354 Stock/Super Stock |
Liked 70 Times in 29 Posts
what CFM is the motorcraft Duane?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
on the wet flow bench at work its a hole 580
To clarify, the 4300 Autolite is different from the 4300D Autolite in that the D series is a spreadbore with larger throttle blades than the 4300 "non D", correct? I believe the 4300D was rated at about 715CFM. Correct me if you have other info (I run the 4300 non-spreadbore).
And I probably should not reference this as a "spread-bore". Square flange or spread-bore flange may be more accurate.
Jeff Lee 7494 D/S '70 AMX |
Liked 333 Times in 180 Posts
According to a buddy of mine these are the specs for both carbs
4300 Carb depending on the particular model these measurements can vary from 441-605 CFM Venturi 1-1 1/4 in primary Bore 1 7/16 P--- 1 9/16 S 1 9/16 P-- -1 11/16 S 4300D carb 715 CFM Venturi 1 1/4 P Bore 1 9/16 P--2 S This carb (4300D) is ONLY on 71 Boss 351 Cleveland & 72-74 351 Cleveland engines ---4300D carb will only fit a specific manifold -- Not interchangable with a 4300 manifold WITHOUT an adapter!!! Comp 387 |
