Old 10-16-2008, 10:35 AM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Dually Brakes?........
I've tried 2 different sets of brakes this year, neither seem to work very good. Anybody have any good tips on stopping power? I have a 95 Chevy 3500 dually and a 40' trailer. BTW, the trailer brakes work very good, just need more up front.....
Thanks for all the help...
Wade O
Old 10-16-2008, 10:57 AM   #2
Crisco
Liked 47 Times in 21 Posts
Default Re: Dually Brakes?........
Wade, the best ones I found were the top of line Carquest brand for the front. But, the brakes on those trucks aren't the best anyways. My truck had 190,000 miles on it when I sold it and I think I put 4(?) sets on the front (trueing up the rotors each time) and one set on the rear. I pulled a 28' Pace most of the time .
Crisco is offline   Reply With Quote
Old 10-16-2008, 11:08 AM   #3
SSDiv6
Wade O
Do you have the base C3500 or C3500 HD version? The brakes are different between for both trucks. Also, do you have drums in the rear or discs all around?
tell me the details and I may be able to make recommendations.
Old 10-16-2008, 11:22 AM   #4
Crisco
A 95 is disc/drum. I didn't think there was a HD version in 1995? Mine was a 2000....same style as Wades.
Old 10-16-2008, 11:28 AM   #5
SSTRACER323
SSTRACER323's Avatar
Send a message via Yahoo to SSTRACER323
I had a 96 GMC C3500 it is the Hydro boost. They are junk. I changed mine out 3 times and still no stopping power. The Carquest brakes are very good.
I know what you are going through on stopping, I sold my dually and i have a 2003 Chevy 2500HD and it stop's a 1000% better than the dually.
Better gas mileage too.
The Doughboy
Lee Lones
S/ST 323L
SSTRACER323 is offline   Reply With Quote
Old 10-16-2008, 11:30 AM   #6
Rob Petrie E395
Liked 216 Times in 77 Posts
I run the titanium metalic by wagner on the front of my 98 K3500. I pull a 44' haulmark, I weight right at 24,000 total wieght and it has great stopping power. I work on a ton of these trucks as it seems every farmer around here has one. The one thing I have found is that after these trucks get around 100K on them the hydroboosters do not make as much pressure as they did originally often times creating less than expected braking capibility that is usually only noticable with a loaded trailer. If you are having trouble stopping start checking pressures and I think you will find a rebuilt booster will dramaticly improve braking when pulling a heavy trailer. I put about half dozen a year on and owners are always amazed how much better the truck stops afterwards. By the way if you do end up needing one the ones from O'riellys are the best value they are just as good as the ones from Napa and half the price usually around 150 my cost for a rebuilt unit. And as always make sure rear drum brakes are adjusted up you would not believe the number of trucks I see with stuck adjusters
Hope this helps
Rob
Just happend to call for some other stuff they went up 180 exchange now
Old 10-16-2008, 11:36 AM   #7
Crisco
Hope this helps
Rob
Wish I would have known that a long time ago about the booster.... Rob, do you see alot of warped rotors on these trucks?
Old 10-16-2008, 05:36 PM   #8
Rob Petrie E395
No on 2wd at least nothing that cant be machined out, yes on 4wd and almost always are so bad they need replaced to fix properly, I think it is because of the way they made the 4X4 setup not a good design in my opinion. bad part is on the 4wd you have to pull the whole hub/rotor assy and press it apart to change rotors its not a quick job by any means. The most common thing I see on these trucks both 3/4 and 1 tons is very few people check rear brake adjusters to make sure they are functioning properly and keeping the brakes adjusted. Second is bad boosters. As far as front end shimmy goes I have yet to see one of these trucks with over 50K that did not need a idler arm and pitman arm they are junk from the factory. Best solution that cures the problem is the moog problem solver parts a little bit higer than the standard stuff but they last. I put them on my truck at 45K now have close to 130K on it and they are still tight. Now if you want to really see a problem find a truck with warped rotors and loose idler/pitman arms hook a big load to the back and try and stop, it will almost jerk the wheel out of your hands. I have tried the Tow Truck valve. works a bit better for when you are towing a trailer But if you drive on snow or bad roads like we have around here in the winter time it can be a handfull because it seems to want to lock up the rears and try and make the truck swap ends. ( I took it back off mine for fear if I let someone else drive the truck it would get wrecked.
Old 10-16-2008, 12:10 PM   #9
Wade_Owens
Wade_Owens's Avatar
Mine has discs on the front and drums on the rear. It does not have HD anywhere on the truck. Its too old to get the options list from GM, I already tried......
Wade
Old 10-16-2008, 12:41 PM   #10
SSDiv6
Wade
Wade,
These are my recommendations:
Front Rotors:
NAPA P/N: 86593
Front Pads:
Satisfied Brakes Fleet P/N: FL459
or:
NAPA P/N: SD7339M
Rear Shoes:
Satisfied Brakes Fleet P/N: 452NR
or:
NAPA P/N: SD452R
Before you install them, find a place and have the rotors, pads and shoes cryogenically treated. It is worth every penny and the results are worth the cost.
