Old 12-06-2008, 12:11 AM   #1
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Default g body rear suspension
Just wondering if these trailing arms would be considered legal for a 79 malibu nhra stocker. The rule book say's NHRA accepted non-adjustable oem type lower traling arms allowed. What would be considered NHRA acceptable? Has anyone used these arms? They are made by a guy called Iceman Products. Thanks in advance for any help.
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 12-06-2008, 02:19 AM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: g body rear suspension
They have been so far.
The Lakewood (Southside Machine) bars are also legal as long as you don't weld the lowering plates to the housing.
As long as it is truly bolt on to stock locations, and now I understand, not adjustable for length on the lower bars, it's legal stuff.
"Despite the high cost of living, it remains popular."
Dave Cook
NHRA N375
Dave Goob Cook is offline   Reply With Quote
Old 12-06-2008, 05:27 AM   #3
Bud Lefevre
Bud Lefevre's Avatar
Yes that setup is legal , and very good stuff too.
Bud Lefevre 3075 STK
IHRA World Record Holder
Bud Lefevre is offline   Reply With Quote
Old 12-06-2008, 05:57 AM   #4
Rory McNeil
Hi Dave, I`m guessing you bought Pete`s old car? Very cool! See you out there next year!
NHRA 6390 STK
M/S 85 Mustang
Old 12-06-2008, 11:46 AM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: g body rear suspension
That's a non-adjustable lower arm as to it's overall length.They don't want someone altering the wheelbase of the car. The adjustable uppers are OK because they CAN'T change the wheelbase,just the pinion angle.Looks like a nice set up.
Old 12-06-2008, 02:09 PM   #6
Dave Jung
Dave Jung's Avatar
Thanks for the replies guys.
Hey Rory, ya I bought Pete's car and I'm going to re-do the suspension and brakes this winter and see what it will run. can't wait to get it out. I was going to get Alf's set up , but since it might be illegal , I'm gonna try some other stuff.
Here's what else I plan on doing if anyone has any input it would be appreciated.
urethane body bushings, QA1 stocker stars, del alum bushings, low friction ball joints, moroso front springs, solid lower and adjustable upper rear arms, rear bolt on arb, solid upper bushings in rear end housing, areospace front and rear brakes.
I'm kinda on a budget, so Afco d/a's etc. are out for now.Are ball joint spacers allowed? are longer ball studs doing the same thing? what brand of bolt on arb would you reccomend. I'm also planning on using some moog rear springs with the same rate left and right , and let the arb even out the body on launch. Also, should I be re-locating the upper arms at the housing?
6535 stk
81 Malibu K/SA
Old 12-07-2008, 04:55 AM   #7
Bud Lefevre
Since your on a budget , look into Calvert front shocks. Got mine from Alex Denysenko ( monymkrssla@AOL.COM ).
The Del-A-Lum bushings from Global West are nice , but a real pain to put in. I think I would see if they offer instalation if I was going to do them again. I used the softest Moroso spring and didn't have to do any cutting.
Might as well put an airbag in the right rear now , you'll end up with one anyway.
What rear end are you useing , 10 or 12 bolt ?
I haven't tried relocating the upper arm yet , but plan on trying it and see if it makes any difference.
Here's a website you can look around on, these guys know how to make a G body work with stock suspension.
http://www.maliburacing.com/
Bud
Old 12-07-2008, 09:14 PM   #8
Dave Jung
Dave Jung's Avatar
Bud, I'm using a 12 bolt made to fit. Do you still need an air bag with a anti-roll bar? I've also got the softest moroso spring to install. I've been on maliburacing, thats where I saw Iceman's stuff. What kind of 60 ft times do you get?
Dave
6535 stk
81 Malibu K/SA
Old 12-08-2008, 06:26 AM   #9
Shawn S.Kvaas
Dave,Pete had a 12 bolt in his car?
Shawn
Shawn S.Kvaas is offline   Reply With Quote
Old 12-08-2008, 03:05 PM   #10
Phillip marvetz
Phillip marvetz's Avatar
Hey Dave, The caltrac shocks changed the 60ft in franks car from a 1.55 to a 1.50. Best money he ever spent,lol
