Old 12-24-2008, 11:36 AM   #1
Michigan Skip
Default You guys running LT1's
I have to assume you are running aftermarket EFI, so how does your aftermarket PCM deal with the Opti-Spark?
Skip Willis
95 Z28
IHRA ST/666
Michigan Skip is offline   Reply With Quote
Old 12-24-2008, 04:47 PM   #2
csjta
Default Re: You guys running LT1's
On my car I use a FAST system. It's uses a crank trigger and only uses the Opti to fire the plugs.
HTH
csjta is offline   Reply With Quote
