Old 04-04-2009, 07:33 PM   #1
partsbob67
Liked 79 Times in 11 Posts
Default sherman lifter help
i have a set of sherman lifters in my 92 mustang 5.0 l/sa. i can't get these things to work. the instructions say to set them with .002-.005 lash.i set them at .005. after 3-8 passes they start to tighten up and hold the valve open. is this the way they are and need to be adjusted after every pass? help!!!
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 04-04-2009, 07:41 PM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: sherman lifter help
Not @ all! I have a set in the 6cyl in dads car they were set in 06 & haven't been touched! we set them with a filler's guage @ .002 cold just like you would a solid? that's a hyd roller you have so not sure but should be the same? you have a good set of poly-locks?
Old 04-04-2009, 07:53 PM   #3
partsbob67
Default Re: sherman lifter help
brand new. new springs the works. they did the same thing last year with stock rockers and fulcrums that i shimmed for clearance. the new heads are stud and polylocks with early ford rockers. wonder what is wrong?
bob beals 7244
Old 04-04-2009, 10:33 PM   #4
Jeff Lee
Jeff Lee's Avatar
I suspect you're not were you think you are on the cam lobe when adjusting valves. Stocker cams are REAL touchy. Bumping the engine with the atarter is a good way to screw up valve lash adjustment. I would suggest EOIC while rotating the engine with a wrench.
Jeff Lee 7494 D/S '70 AMX
Old 04-04-2009, 11:01 PM   #5
greg fulk
greg fulk's Avatar
I'll 2nd that...stocker cams are "funny" we "rock" the cam a couple time to make sure it's on the base circle.
Old 04-05-2009, 08:00 AM   #6
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Heres also what I feel is screwing things up. I had similar issues like this one.I feel the lifter is bled down when you are adjusting the lash! It will tighten your lash when the lifters fill back up from oil.(ex engine runs for a minute). I would loosen things up, start the engine do one side at a time (quickly as to not let the oil bleed out) then do the other side. Now if this does not work I can tell you the lifters are junk. Trust me as im not going to get into the full details but I have taken these lifters apart and was very suprised at all that makes them work or not work. Also call Allen and tell him the status and they can guide you more. Hope this helps Mike
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 04-09-2009, 09:28 AM   #7
Sherman
Smile Re: sherman lifter help
Questions on Sherman Lifters can be answered by Cliff. He can be reached at 225-473-4923 or 225-717-1460. Email address is shermanracing@bellsouth.net
Sherman is offline   Reply With Quote
