View Poll Results: .031" Dykes or .043" Rings ?
.031" Dykes 41 33.88%
.043" .155" radial moly ring with lateral gas ports 39 32.23%
.043" .134" radial moly ring with lateral gas ports 31 25.62%
Other, Make suggestion 10 8.26%
Voters: 121. You may not vote on this poll
Old 04-24-2009, 07:03 PM   #1
trmnatr
Default .031" Dykes or .043" Rings ?
Gonna put new lighter pistons in the 331 (327) , I know im gonna go with a 3mm oil ring. I know im gonna go with a .043" napier second ring
Here the thing, Should i go with an .031" Pressure Back Dykes Top Ring or an .043" .155" radial ring with lateral gas ports ?
Engine Combo..........
- 4.030" bore GM block, filled with Hardblok, Milodon Splayed Main Caps with Milodon Main Studs, using ARP head studs too
-Bryant billet 4340 3.26" stroke 40 pound crankshaft , 350 main size with 2" rod pin and big block chevy snout
-GRP aluminum rods 478grams 349grams big end 129grams beam end , ARP 3/8" 8740 rod bolts
-Crane Solid Roller Cam 308/314 @.020" 278/284 @.050" 200/206 @.200" .670"/.670" 106 lobe seperation, Mikronite processed, 1-8-7-2-6-5-4-3 (4/7 & 2/3 firing order swap)
-Shaft Rockers with 5/8" shaft
-Jesel Belt Drive
Pistons will be 2618, They will be lightweight plus they will have some work done to them by Rebco Machine to lighten them up
Here are my options on rings, give me your opinions
1) .031" Dykes
2) .043" .155" radial moly ring with gas ports
3) .043" .134" radial AP ring with gas ports
4) Other, make suggestion
Piston weight should be around 400grams plus wrist pin which should be around 95grams. Pistons will use a pretty good dome size due to 62cc heads and .040" quench
trmnatr is offline   Reply With Quote
Old 04-25-2009, 04:38 PM   #2
Bub Whitaker
Default Re: .031" Dykes or .043" Rings ?
NO to Dykes
.043 lateral gasports wins hands down, AP will last longer, But make sure you make the backspace correct for whatever ring you use...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 04-25-2009, 04:44 PM   #3
trmnatr
Originally Posted by Bub Whitaker View Post
NO to Dykes
The pistons will be cut so there is .005" back space
Why dont you like the .031" Dykes ring ?
Old 04-25-2009, 04:58 PM   #4
Bub Whitaker
too heavy / ring flutter... also dont really start working till high RPM and then we have the flutter...
Bub Whitaker
Old 04-25-2009, 06:05 PM   #5
trmnatr
I have never had any issues with them, maybe thats because the leave rpm has always been 6,000rpm and up
Yes they do smoke some until gas loading at higher rpm, have noticed this
Old 04-25-2009, 09:45 PM   #6
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: .031" Dykes or .043" Rings ?
I have tried just about everything out there, and for my money I choose the 5/64 back-cut top and second ring with the low tension oil ring by Tri-City Competition Service, for a stocker motor that is with the 5/64 ring lands. Call Greg Luneack @ 760-630-9094 He will fix you up, and he is a great guy to deal with.
Jim Cimarolli is offline   Reply With Quote
