Old 05-03-2009, 09:26 PM   #1
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default C-12
Just a few quick questions. I bought a five gallon drum of C-12 last week. The place I buy it from used to pump it out of 55 gallon drums into a regular plastic jug. Will it affect the fuel one way or the other to leave it in the metal drum, or dump it into the plastic jug? I'm meaning if it will check any different at fuel check, if it will "keep" better in one or the other. Also, it was $65.81 for the five gallon drum. The last time I bought fuel, in the fall of 2006 it was $8.62 a gallon when I bought it the way I mentioned earlier. Is $13 a gallon the normal, going price or am I paying too much? Thanks.
Old 05-03-2009, 10:22 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: C-12
Mike, Keep it in the metal can as long as you can! C-12 seems not to like the plastic jugs or fuel calls. When I was running C-12 last year it went bad quickly and they recommended you to pull it out of your tank and store it in metal containers between races. I got tired of almost being tossed several times because of it and went to C-16. I use C-11 now in the Volare and it seems to be much more stable than the C-12. I just paid $60 for 5gal ($12 per Gal.) at the SGMP points race. Hope this helps. Jim
Old 05-04-2009, 05:47 AM   #3
bobby
bobby's Avatar
Default Re: C-12
I thought the 8.50 I was paying was expensive.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 05-05-2009, 04:37 PM   #4
chevy620
Banned
Default Re: C-12
I am sick of paying $12.00 a gallon and I have only bought 8 gallons!
What about the Rocket 111? Work about the same as VP?
Where can I get it? Does it cost less?
What about Sunoco 110 or 112 in a LT-1 stocker? Does fuel really make a difference with the lower compression.
Man, I use Rocket 114 in my other car, 632" Chevy and it is only $8.00 per gallon.
Can I get 10-15 gal of Rocket 111 from someone at Norwalk LODRS event in a couple weeks?
Thanks for any help on beating down those outrageous VP prices. WOW!
Jok
chevy620 is offline   Reply With Quote
Old 05-05-2009, 06:12 PM   #5
Bob Shaw
Liked 323 Times in 63 Posts
Default Re: C-12
I have used C-12 for years. The last I bought would not pass fuel check and VP would not replace it. They told me I could use it for bracket racing. I switched to Sunoco 110. It was $2.50 a gallon cheaper and it runs the same.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 05-06-2009, 07:34 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: C-12
When you buy 5 gallons VP that comes in metal can you are also paying for the can which is about $15.00 of price.VP price comes down alot per gallon when you buy 55gallon drum.
Mike Taylor3601
