Liked 165 Times in 59 Posts
transmission guys:
last week had my th400 transmission miss second gear several times ,but it was intermitent to where i was able to get 3 full passes out of thee eight atemps(you could feel it hit and then the motor hits the chip) ,get back to the pits and put it second and the gear held (flash the converter to 4000 in second) sometimes work and sometimes not,take the trans out bring it to my builder and tear it down,the trans is perfect no clutches burned,fluid red,checked the spags (witch i thought for sure would be the problem) but they look ok my questions:can a sprag roll over and not break the outer race,is it possable that it could just not lock up is it possable the converters sprag is bad and note the converter has only 4-5 % slipage full manual tci valve body any help would be greatful gmonde |
Liked 359 Times in 103 Posts
First thing to check is the shifter and cable. Any slop at all change the cable. It may be going past or not quite getting to the right spot in the valve body every time.
Cables or sloppy linkage has caused more problems to not be a real issue. Been there done that and felt stupid afterwards after pulling a trans 3 times taking it apart 3 times then fixed by changing the cable. My 2 Cents |
after the second pass attempt thats what i did,jacked the car up and make sure the cable was adjusted and didnt go past the detent when shifting ,,,,i wish it was that gmonde
Liked 5 Times in 3 Posts
what shifter do you have? We had a Hurst pro matic in one of our cars it did the same thing...it was a ratchet style & would not catch the notch sometimes! Sent the shifter back & go a new 1 no more trouble.
hurst quarter stick,solid gate operation gmonde
Just checking the detent is OK but I did the same thing 3 times before changing the cable.
Cables cause more problems than people think. If it is several years old I would still look at it. As a cable gets older it will get loose on the compression and stretch. Like I mentioned earlier pulling the tranny out and apart 3 times with no problems found but changing the cable made me feel pretty dumb a few years back. The cable looked good and I thought it was good but changing it sure did fix the problem. My 2 Cents |
Liked 1,892 Times in 423 Posts
Yes, it is possible to roll a sprag and not break an outer race.
The sprag in the converter would not just affect one gear. Do not do stall tests, loading the converter and not allowing it to release by launching the car will kill the converter. Is this a new transmission, a new valvebody, a fresh rebuild?
Alan Roehrich 212A G/S |
