Old 05-04-2009, 11:17 PM   #1
nhra2864
nhra2864's Avatar
Default 4th gen f-body 95 camaro manual brakes question
What do you guys run? I set mine up and I can't hardly stop the car. The pedal is very hard and you have to stand on it to stop the car?
Thanks,
Justen
nhra2864 is offline   Reply With Quote
Old 05-04-2009, 11:38 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: 4th gen f-body 95 camaro manual brakes question
Did you repositon where the rod attaches to the pedal to get the correct pedal ratio? Billingsley racing recomends the hole be 1 inch above the factory riviot that the stock rod attaches to. This is how I did mine and its been great.
Old 05-05-2009, 05:32 AM   #3
bobby
bobby's Avatar
I did that on a 77 Firebird. Rock solid until I moved the rod up 1 inch to the next hole.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 05-05-2009, 11:34 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
The stock hole only provides about 4to1 pedal ratio. ....Moving about 1" to 1 1/4" inches gives about 6, 6 1/2 to 1 ratio. ......Tom
Old 05-06-2009, 12:34 AM   #5
nhra2864
nhra2864's Avatar
I moved it up 1 inch and then moved it back 1/2 inch because the angle looked way off on the pushrod.
