#1 i have picked up a 69 camaro, has a roll bar welded in and the front clip is also welded to connectors to the roll bar. problem is the wheelbase is 108.16 on the left and 109.00 on the right. any ideas? does the 3/4 inch rule still apply, do you run an unequal wheel base?
#2 how much of the engine in stock (1969 bbc) is stock-not aftermarket parts-if i just started with the block, heads and crank would i be correct in assuming that the correct aftermarket parts are available? thanks in advance ![]() |
Liked 16 Times in 11 Posts
3/4 rule still used, maximum variation from left to right 1" as per rule book. It is like that to keep the wheels in the beams longer, it is legal. The block, you can use any GM block even a bowtie, stock crank and aftermarket rods listed on nhra site. In some cases you can use the GM alum heads 401 otherwise only what is listed in the blueprint spec sheets listed at nhra. there is also a replacement intake in some cases, not knowing what you are building limits what I can tell you. If you would like anymore info email me I would be glad to help.
Bob Pagano A/SA |
