Old 06-15-2009, 08:52 PM   #1
njk53
Default Another Line Lock Question
What would be the cause of a line lock not holding the car properly? When I set it, you can feel the solenoid click and engage the front brakes but, when you do a burn out it doesn't hold the car in place like it should. The line lock solenoid is a Biondo w/ a Hurst Switch. I was told to check for air in the lines which I will do. If it isn't air in the lines what other things should I check?
Nelson Kowal
Stock 345
Old 06-15-2009, 10:46 PM   #2
larry dowty
Liked 11 Times in 4 Posts
Default Re: Another Line Lock Question
make sure you have it going the right direction?
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 06-16-2009, 05:01 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Hold the switch, and pump the brakes a couple of times....
Old 06-16-2009, 07:46 PM   #4
njk53
Larry:
Do you mean direction of flow? Also, is it common that you have to pump the brakes a couple of time before you set the switch?? Someone else suggested the same thing.
Nelson Kowal
Stock 345
Old 06-16-2009, 08:14 PM   #5
larry dowty
yes they are directional, i know from experience i just had the exact problem with my new stocker and it was the dork that built the car LOL turned it around and the brakes work perfect
larry dowty 6388 SS
Old 06-16-2009, 10:56 PM   #6
Those things are rebuildable. Unscrew the brass part from the coil portion. Pull the piston out. There is a little seal that covers the orifice in the middle. Check the condition of the seal ,and that it's not pushed back too far.
Call Sal and see if he'll sell you a kit.
