Old 08-03-2009, 10:55 PM   #1
RJ Sledge
Liked 291 Times in 92 Posts
Default towing enclosed trlr with motorhome??
I am thinking of buying a late model gas powered motorhome,30 ft Class A, V-10, Ford chassis unit. I see m/h's this size towing enclosed trailers all the time and was wondering what people do about the hitch or modifications to them. Most of the mh's i have been looking at only suggest pulling a 5000 lb max trailer. Now I know that some of the ones I have seen are heavier than that so what are people doing to the hitch to modify it so it won't ripe the back of the motor home off?
Thanks RJ Sledge
RJ Sledge is offline   Reply With Quote
Old 08-03-2009, 11:25 PM   #2
bill dedman
Liked 6 Times in 4 Posts
Default Re: towing enclosed trlr with motorhome??
>>>"rip the back of the motor home off?"<<<
Is this motorhome gonna have one of your 390's in it???
Bill
bill dedman is offline   Reply With Quote
Old 08-03-2009, 11:28 PM   #3
RJ Sledge
No Bill it won't.....sorta wanted to get there and back!!
RJ
Old 08-03-2009, 11:47 PM   #4
bill dedman
Don't be so self-effacing.... I know those things would move the Empire State Building off its foundation if you just hooked one up...
Excellent choice for a motor home/toter home powerplant!!!.
Just make sure the hitch area is double-wall 4130 and you'll be okay!
Bill
Old 08-04-2009, 06:08 AM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
Get a hold of Jim Bailey. He sells some frame braces that attach to the hitch and strengthen the frame.
Jim Kaekel 3836 STK
Old 08-04-2009, 07:03 AM   #6
Bill Harris
Liked 26 Times in 13 Posts
Hi RJ. I do exactly what your looking at doing. I sent you a PM.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 08-03-2009, 11:46 PM   #7
DIC GEARY
Liked 6 Times in 5 Posts
Rj you have a pm...
DIC GEARY is offline   Reply With Quote
Old 08-04-2009, 08:06 AM   #8
Red LeBlanc
RJ if you get The Motor Home . You can rent the apartment in the trailer .. LOL LOL . Red Le Blanc
Red LeBlanc 4998 SS
Red LeBlanc is offline   Reply With Quote
Old 08-04-2009, 08:49 AM   #9
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
I've been towing with a class c and a 24 ft trailer for better than 3 years with no problems. Most motorhomes have frame extensions which are actually the weakest link. You must visually inspect the frame to check for cracks or broken welds. That being saild I have not had any problems with my setup. The trailer needs to be loaded properly as to shift as much of the weight off the tounge. I believe the tires on the motorhome and trailer will take the most abuse. So purchase the biggest and strongest tires you can fit under your rig
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-04-2009, 09:13 AM   #10
Wes McCracken
I highly recommend using a Trailer Toad. Takes all the tongue weight off the motorhome. Call me if you have any questions. 570-323-6649
Wes
Wes McCracken 1189 STK
Wes McCracken is offline   Reply With Quote
