Liked 60 Times in 12 Posts
As far as GM's go, has anyone done any A-B-A testing, or a real good A-B of which is more efficient, the 10 bolt (8.5) or the 12 bolt. Looking in another area, for some gains for future.
Thanks ! Kenny .
2894 STK |
Liked 99 Times in 60 Posts
Kenny, I have no test results but offer these thoughts. The 8.5 will be at least a few pounds lighter and has proven to be completely acceptable in even very high powered cars.
From the view point of mechanical losses, I do not think the difference will be enough to measure, I think either choice will give good results. Is this for your stocker? If so, what are your running now?
Larry Woodfin 471W |
Yes, thanks Larry. I was thinking of trying to make it as effiecient as it could be. I have the 10 bolt in mine now, and was wondering if the 12 bolt was worth a swap, as far as reducing the losses wherever they are.
2894 STK |
I think you have the best choice. Going to a 12 bolt would not gain anything, in fact, I think you would loose ground because if nothing else, the added weight.
Liked 719 Times in 220 Posts
Once you put a spool,good axles, wheel studs, the proper bearing kit and steel web caps in the 8.5" 10 bolt,(which you do to any race car rear end,anyway),it probably has 90-95% the strength of a 12 bolt. I don't think the weight is more than 5 pounds difference, but cost and availability is a real factor here. I wouldn't pull out a 12 bolt in any of my cars for a 10 bolt because they are there already,but if I had the 8.5" 10 bolt, I would go no further in my search. One advantage to the 12 bolt is the availability of gear ratios is larger.
Liked 69 Times in 32 Posts
i just switched from a 8.5 ten bolt to a 12 bolt and with similar
components and same gear ratio i think the 10 bolt was .03-.05 quicker, both are set up the same way. |
