I know they are used in TF TA and ProStock fairly frequently.
Does anyone have any experience with titanium valve springs ? They have a lot of properties I am interested in , rate as well as strenght for limited life applications, I would love to hear from anyone that has run them, pros/cons. |
#2 | |
Ed Wright 4156 SS/JA |
Liked 196 Times in 29 Posts
I had the priviledge of driving John Lingenfelter's old A/ED transformed into a B/ED in 1999. John had some early Pro Stock Truck wedge engines that he wanted to sell along with the dragster, so we got together with some of my parts and ran them for four races in that summer. Prior to going to the Bowling Green points meet, John decided to put titanium valve springs on this engine. He told me to keep an eye on them because they were only good for twelve runs and these had eight runs on them already from one of the then, current Pro Stock truck motors. He also told me that they were $150.00 a piece. After the 2nd qualifing pass, the car lost 5 MPH, and as it turned out, it did have a broken intake spring, so he told me to not take a chance and change all of them and it would be good thru this race and Indy.
This was way to expensive for my pocket book and I really don't know if I saw anything in them. I would say today's springs are probably a lot better than those were and obviously, a lot cheaper. We have ran our PAC springs for many-many runs without problems at 10,500 RPM. Gary Merrick 3522 C/ED |
We have run them in the past on some engines and our experience was identical to that of Mr. Merricks,they were great if you were on an unlimited budget and did'nt mind checking the springs after every pass.This was also quite some time ago say 90-95,so it is quite possible that there have been significant improvements in titanium sice then.
#6 | |
Thanks for the info, after a couple days of research, I found out what I needed to know, when they fail, they fail catasrophicly.....breaking like a candy cane and leaving shards everywhere, the tension of a spring breaking in relation to steel is huge, and as a result the resulting teardown and rebuild equally as massive.
I was looking to save money in the long run if they were more durable, it dosent seem that they are in for the long haul in a stocker, if they cost $1800 a set and lasted all season without failure, and could help eliminate valve float at absurd RPM, its a no-brainer, but unfortunatley this isnt the case. Im limited to beehives, and well single springs make me nervous for high revs......they just do....So I was looking for something maybe on the material side to help, and the engine Im running is prone to breaking them in just this scenario. Thanks for the info guys you pointed me in the right direction. Quote:
