Old 05-27-2007, 08:52 AM   #1
cambria
Default opti-spark hell
Mayday-----I have gone through 15 opti-sparks,bought the new so call billet MSD and still I blow them constantly.I am told that someone has figured out how to make them last.Who and how please I need help in a hurray.
Paul Cambria
BS/A,A/FIA 00 Camaro-
CS/A, B/FIA 94 Camaro .2012 copo 4.0
cambria is offline   Reply With Quote
Old 05-27-2007, 10:29 AM   #2
FED 387
Liked 330 Times in 178 Posts
Default
Go to Corvettefever.com website look for Opti-spark under HOW TO section gives a detailed step x step with pictures way to solve any problems with these units... Hope this helps , it solved mine on my Bro in laws street car---Comp 387
Old 05-27-2007, 10:40 AM   #3
FED 387
Default
Also go to GMhightechperformance.com this site tells you about the 3 versions of the opti spark how they work what makes them malfunction, trouble shooting symptoms and how to correct any problems, caused by the LT-1 opti spark ignition system failures too. I am sure with both of these sites you will be able to see and figure out your problems and hopefully correct them too. Comp 387
Old 05-27-2007, 07:58 PM   #4
BIGGG
Guest
Posts: n/a
Default
woodro has always done mine-never had a problem biggg
YOU CAN'T PUT A PRICE ON A GOOD TIME
Old 05-28-2007, 03:39 PM   #5
Ed Wright
Ed Wright's Avatar
Default
Paul Cambria
Paul, most are caused by the rotor retaining screws coming loose, or the metal blades coming off the rotor. Red locktite is how I fix the screws on mine, and aliminium pop rivets to hold the blades on instead of the plastic pegs they are mounted on.
Too much cam end play, or too long dowel pin in the end of the cam causes havock also. Had one (rotor) come apart Sat in mine, but hadn't riveted the rotor together. Had a riveted one in the tool box, but not the car. Don't claim to be bright. I just use an original GM unit in mine. Avoid an Opti from Autozone, etc.
Be interesting to hear what (if anything) Woodro says about this.
Ed Wright 4156 SS/JA
Old 05-28-2007, 08:40 PM   #6
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
Default
Call Steve Hanby 503-931-6224 he has the fix! Problem solved.
"Go With Confidence"
Tommy Gaynor is offline   Reply With Quote
Old 05-28-2007, 08:49 PM   #7
LILWJ
Guest
Posts: n/a
Default
Paul are you using a crank trigger and just using the optispark to fire the plugs?
woodro josey
I miss Buster Couch and Lex Dudas.
Old 05-29-2007, 09:52 AM   #8
cambria
Default
Just the Optispark
Paul Cambria
Old 05-29-2007, 10:24 AM   #9
Chuck Garey
Liked 10 Times in 7 Posts
Default
Paul go to Dynatech engineering, they sell a billet opti-spark that is great a little pricey but install it and forget it.
Chuck Garey is offline   Reply With Quote
