Old 04-25-2010, 09:33 PM   #1
snoopstang
Default ford 4.5l svo v6 complete racing engine
Ford 4.5L SVO even fire engine complete from intake to pan with dry sump pump just add carb. It is fresh with about 6-8 1/8th mile passes. It is upgraded with diamond 10:1 pistons, copper head gaskets with o-ring/receiver grooves, custom turbo roller camshaft. It has all clevite race main/rod bearings, carillo rods, cnc ported heads, ported intake. It made right at 900 hp with 15 lbs of boost. It can be ran N/A with a cam swap. I know where there are several used n/a cams for $100 or less. It will make around 425-450 hp N/A.
I also have the following spare parts included as a package deal. 1 spare set of bare ported heads, set of Jesel roller rocker, head studs, new set of clevite racing rod bearings, new intake gaskets, and a spare parts dry sump pump.
The engine and parts are located in Poplar Bluff, MO. $6000 FIRM. NO TRADES!!! snoopstang@yahoo.com
snoopstang is offline   Reply With Quote
Search this Thread:
Advanced Search
