Liked 14 Times in 11 Posts
2004 F350 diesel/2007 open car trailer.
Seven pin wiring connector. I've got emergency flashers, turn signals and brake lights, but no running lights on the trailer. Am I missing a bad fuse on the truck? #6 on the fuse block is for the trailer wiring and it is a good 20 amp fuse. #37 is for trailer parking lights and that fuse is good too. Open to comments and opinions.
Phil Saran Parker, Colorado Last edited by Philip Saran; 06-29-2010 at 04:27 PM. |
Liked 13 Times in 4 Posts
Look for a second fuse for the trailer running lights under the hood. Not a Ford but my Suburban had the same issue and replacing the underhood fuse was all it took.
Joe Schaechter 3168 STK |
Liked 129 Times in 59 Posts
Philip -
Look for a brown wire coming out of the 7-pin trailer plug. If you've got voltage there, somewhere on the brown wire is a/are splice(s) into the tail and running lights on the trailer. If not, it'll be on the truck side of the connector. Hope this helps! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 8 Times in 3 Posts
Had the same problem with an enclosed trailer. Everything worked except the running lights. Turned out it was a short in the trailer wiring.
Bob Kowal STK 345 |
#5 | |
Liked 101 Times in 52 Posts
Liked 341 Times in 67 Posts
Phil
Just tape flashlights to the trailer fenders. I've been doing it for years. Just remember to turn them on. But if you don't like that there is a relay/fuse under the hood. Mike |
Liked 13 Times in 9 Posts
Dealing with the same thing right now... Replaced all trailer lights with LED's back in February, and everything was perfect until a month ago. Started blowing the trailer parking lamps fuse in the truck. I found a section where it looked like the wires may have rubbed inside a metal channel, so I insulated them, problem fixed. ...for about a week. Replaced that section of wiring, problem fixed. ...for about five minutes ...PER run time! That I *really* don't get. Trailer lights work, then going down the road, they'll go out, then blink on if you go over a bump (for awhile, then they quit completely). Jiggle what you will, nothing. Next day, turn on the switch, and you've got lights again, without touching anything. I could understand something overheating over time and blowing a fuse if something was shorting, but how do they just stop working w/o blowing the fuse?
Same deal, though... all the other lights work. It's just a parking lamp issue. Been turning the parking lights on in the race car if it's dark on the way home. Thinking I'm going to have to do a complete re-wire from scratch to solve this one. Hateful!
Liked 70 Times in 22 Posts
Michael
Don't know if this will help but I had lights thet were on and off so I ran a seperate ground wire from truck to trailer with a single plug and the problem was solved. Quick, easy and cheap to try.
Stewart Way 2424 SS |
Happy 4TH of July to all on the board, sad to see that my
house is the only one on my street flying an american flag. Thank you all for the informative responses. I have checked and I have power for the running lights at the back of the truck (seven pin plug). Tomorrow I'll try adding a temp external ground wire from the truck to the trailer and see if that makes any difference. If not then I will be in the same boat as Mr Beard and need to rewire some on the trailer. Mike Graham, as much as I like your suggestion about the flash lights I have to believe that is a Arizona only type fix, not something that would go over very well here in LA LA land. Of course the CHP does not seem to see my rig when I'm out on the road. Too busy chasing down those bright colored mini box's flying past me on the freeway.
Phil Saran Parker, Colorado Last edited by Philip Saran; 07-05-2010 at 10:52 AM. |
